Help...draining oil today, loosened 17mm bolt just in front of 15mm oil drain plug,
Old Aug 17, 2013 | 01:31 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
Small amount of oil like fluid and spring came out. Reinstalled..what did I do? Was that oil draining out or another fluid?
Old Aug 17, 2013 | 01:54 PM
Danyol's Avatar
Danyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant futureDanyol has a brilliant future
Picture?
Old Aug 17, 2013 | 01:56 PM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Which bolt did you loosen? Open this link that shown how to do the oil change. It has good picture to go along with the description. Note that a lot of guys don't bother with the turbo plugs, since so little oil comes out.
http://forums.rennlist.com/rennforum...-diy-pics.html
Old Aug 17, 2013 | 02:56 PM
drhenrock's Avatar
directly in front of the oil drain plug in the center of the car, about 4 inches towards the front of the car from the oil drain plug
Old Aug 17, 2013 | 03:27 PM
pumptech's Avatar
pumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond reputepumptech has a reputation beyond repute
Sounds like oil relief valve or something.
Old Aug 17, 2013 | 03:30 PM
pumptech's Avatar
Parts 9-12 on diagram I expect?? Should be fine.
http://www.jimellisporscheparts.com/showAssembly.aspx?ukey_assembly=472396&ukey_make=1 058&ukey_model=15408&modelYear=2002&ukey_category= 20118&ukey_trimLevel=18178
Old Aug 17, 2013 | 04:55 PM
drhenrock's Avatar
Looks like it I think, thanks...anyone else have opinion?
Old Aug 18, 2013 | 01:05 AM
pat's Avatar
pat
pat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond reputepat has a reputation beyond repute
What transmission do you have. The tip or stick shift. Could be the trans fill chech valve fill port.
Old Aug 18, 2013 | 08:04 AM
drhenrock's Avatar
6 speed, had a spring that popped out ....
Old Aug 18, 2013 | 10:56 AM
Tim941NYC's Avatar
put spring back in and tighten it up.
Old Aug 18, 2013 | 12:37 PM
drhenrock's Avatar
Did that. What is it? Was that oil or gear fluid...?
Old Aug 19, 2013 | 05:04 AM
Tim941NYC's Avatar
Its oil. It is a bypass.
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
Lucid Moment
Aug 20, 2015 02:22 PM
cab83_750
Aug 19, 2015 12:37 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
