2001 996tt help codes
Old Oct 29, 2013 | 09:34 PM
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
Posting for a friend found this codes, ordered maf to start with that
Old Oct 29, 2013 | 11:47 PM
996tt550hp's Avatar
996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute996tt550hp has a reputation beyond repute
Looks like you have more then a MAF problem but hot film is a bad maf senssor or its going.
Old Feb 25, 2014 | 04:50 AM
contigo's Avatar
New MAF, New Plugs, New N75, New MAP sensor, air leak test, vacuum hoses all correct, tried the car with straight pipes hoping for a bad cat... . All codes are gone still getting that throttle doesn't respond immediately from idle...slight hiccup hesitation.
Any one Please
Old Feb 25, 2014 | 04:54 AM
contigo's Avatar
ID:	338994New code Help please. Already tried new N75
Old Feb 25, 2014 | 09:29 AM
996tt550hp's Avatar
How much boost are you running? sounds like your over boosting into limp mode......
Old Feb 25, 2014 | 04:01 PM
Because_R4CEC4R's Avatar
Because_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud ofBecause_R4CEC4R has much to be proud of
^^ what he said. That sounds very tune related. Maybe a fuel system issue causing it to lean?
the5
Oct 14, 2015 06:46 AM
Zmydust
Sep 10, 2015 12:31 PM
sparks
Sep 8, 2015 03:03 PM
petron5000
Sep 6, 2015 11:20 AM
