Power Steering Fluid
On my 996TT 2004, I performed the 10-30 pumps of the clutch, with the car cold and measured and adjusted the fluid to the "cold zone". After driving the car and up to temp, I measured the fluid using the dip stick cap one no PS fluid was to be found? Any ideas?
If your steering reservoir is emptied take a look at your clutch reservoir. If your clutch reservoir is overfilled it is because the fluid is migrating inside the clutch slave actuator to the clutch system. To remedy this from happening again you will need to replace the slave actuator. (sorry I don't understand what you mean by 10-30 pumps)...
