DIY In Tank Fuel Pump Upgrade. (pic heavy)
#46
Hey John,
Can use this as a replacement, seems to work for a couple years before replacement again. http://www.jegs.com/i/Gates/465/27093/10002/-1
Cheers,
Rob
Cheers,
Rob
#52
As far as fenderwell intakes go IMO they are comical, every set I see looks like its been installed by Mickey Mouse with a big hammer to get clearance and the pipes are smaller diameter than I use anyway, then they are normally mated to a big ugly badly fitting intercooler with little or no ducting or sealing so that a fair % of the cold air getting pulled into the rear intake actually goes around and not through the core. In short I think I would rather sit on a fire ant nest naked with my butt covered in peanut butter before i fitted those !!!!!
911 Tuning Fenderwell intake kit 1000 miles after being fitted
Filters love where they sit !!!
Was it rubbing the tyre at all
Never mind we can 'relieve' that pipe a bit
And its smaller than mine to start with
Even Baby Oleg in the background is giving it sideways looks !!!!
#53
Well the engine is already out so total time to get them on so far is about 20mins and about the same to trim to size when the engine goes back in.You wont rub thru it either when the heat shrink cools the pipe retains its bent shape and it feels plastic coated
i actually have a new idea which I'm going to try in the near future that will allow for even more flow
#54
OK so have you had to flatten the pipes to get them past the tyres? We have a fair bit of rain in the UK which accounts for the stat of the filters but almost EVERY FW install ive seen has battered pipes and it must be 'interesting ' getting those coolers in to the factory brackets and ducting and sealed. But my intakes are still bigger diameter than yours and easier to fit !!!! And a lot cheaper I think.
#55
#56
Tim the reason to use bigger hoses than the intake diameter of the turbo is air volume to the turbo, same as some people run -10 lines to a -6 fuel rail and fireman use big hoses with small ends !!!!, for example a tuned big block chevy would empty and engine dyno room of air in seconds but thats only going through say 8 small holes (with dual quads) !!!
#57
must be the metric system in the uk!
#58
Well the bigger hose surely holds more of a 'reserve' of air same as the bigger fuel line would hold more of a 'reserve' of fuel and as the turbo is in effect a pump then the diameter of the intake to that pump is irrelevant compared to how much air it is drawing in! Either way I think we are both in agreement that we would not fit smaller pipes and always fit the largest pipes we can.
#59
That poor intake pipe looks like it fell off and got bounced around in the wheel well a little bit!!
I'll be trying to stuff 3" intake pipes off of my turbos soon! As it looks right now...it will be a challenge!
#60
If you could buy a 3" pipe that was an oval and can 'lobster tail' the bends maybe it can be done but you could fit 3" pipe like mine easily !!!!, mine is 2.75" and thats all I need.
