Boxer motor head gasket failures
Just spent today pulling the motor and replacing the head gaskets on the wife's Subaru Outback due to an external failure resulting in a coolant and oil leak onto the exhaust manifolds. In researching this issue with the Subaru, it's a very common problem. As I as working on the car, I got to thinking, is this a common problem on the TT? I did a quick search on this forum and didn't find much. Just wanted to see if there were many failures on the TT's? On the Subie's the boxer design apparently puts pressure on the lower side of the gasket, leading to erosion and external failure and leaks.
In regards to which year(s) are bad, I believe it's the 4-cylinder, EJ25 motor which is prone to failure the most. This is the single over head cam, 4 valve model. from 1998 to 2003 the were so bad, Subaru extended the HG warranty to 8 years and 100k miles. This expired for my year, 2006, and Subaru claims the "fixed" the issue, but that only means the failure rate is less then before. Usually found in the Legacy, Outback and Forester in NA models. I heard the turbo versions use a 3 layer gasket which does not fail as much
johnny.dangerous
Sep 11, 2015 02:39 PM
