Erp Triple vs Clutchmaster stg 3- can someone give me a good camparo
Old Feb 23, 2014 | 10:08 AM
Wealth Manager's Avatar
Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !Wealth Manager Is a GOD !
I have researched it. I just wanted to see if anyone had both and good give a good comparison.
I have the clutch master stage 3 currently with GT2 conversion and find the engagement is rough and some drivability goes out the window.
I was seeing if people with the ERP Triple find a lot more drivability with it? This car will not be tracked and mainly just some highway pulls on the weekends but I feel the CM stg 3 just takes some enjoyment away from driving the car.
Thanks......
Old Feb 23, 2014 | 10:45 AM
Fire's Avatar
Fire is just really niceFire is just really niceFire is just really niceFire is just really niceFire is just really nice
My CM clutch/gt2 setup is awesome as far as drivability goes... I do still have the assist spring on. Ive only run multi disk on Nissan applications. Softer but noisier.
Old Feb 23, 2014 | 10:56 AM
Yea I have the CM stg 3 and don't like it that much. The drivability is ok in my opinion. I drove my friends GTO the other day and it was like night and day and made my clutch look like crap, his engagement and drivability was amazing, he had a Tilton I think if I remember correctly.
Old Feb 23, 2014 | 03:18 PM
TurboTodd's Avatar
TurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond reputeTurboTodd has a reputation beyond repute
My experience with the CM 3 is all positive. Nice engagement point, very smooth. In fact at idle in first I can slowly release the clutch and get under way.
Old Feb 23, 2014 | 06:01 PM
johnspeed's Avatar
I hated my CM..
Old Feb 23, 2014 | 06:10 PM
joetwint's Avatar
joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !joetwint Is a GOD !
If i remember correctly when i had it on my car u need a slave kit with that clutch otherwise it is horrible.With the slave kit drivability is pretty good
Old Feb 23, 2014 | 06:21 PM
DNugget991GT3's Avatar
Kyle, the erp will feel totally different than a CM. the erp is triple disc. engagement on stock gears will feel like a sachs 2.5... with a (longer) gt2 1st gear (which i think youre doing, right ? ) you'll have a LITTLE bit of judder when moving from a stop, so you'll have to ride the clutch a little more than usual.
an erp is 10000x better than a cm stage 3. you'll never have to replace an erp, even at your expected power levels.
20k miles on mine so far with enough launches to have broken an axle already. lol
think of a erp clutch like pccb;s for your transmission. pccb;s last forever (150-300k miles). an erp will last YOU for at least that much (because youre mostly doing highway pulls)
youre definitely going to want to do a gt2 slave conversion. i recently felt an erp cluch on a 996tt with the hydraulic slave and it felt horrible to me. i didnt "feel" the clutch if that makes sense.
Old Feb 23, 2014 | 06:43 PM
Whereitsat's Avatar
Whereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond reputeWhereitsat has a reputation beyond repute
My CM3 with the lightweight flywheel blows. It holds well, But sounds like crap and engagement is high. If my budget allowed, I would have the ERP.
Old Feb 23, 2014 | 07:28 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
triples will make more noise generally at idle clutch not pushed in, but wont shutter when you are taking off they just hookup.
i had a 964rs steel flywheel and sachs pressureplate in my car at first (same as CM stage1-3) now have a triple disc and the triple is louder at idle.
the release position can be changed some people know what length to cut the shaft so it releases properly. some installers dont.
Old Feb 23, 2014 | 07:45 PM
Whereitsat's Avatar
Evidentially, my installer needs a lesson. Is it difficult to correct now?
Old Feb 23, 2014 | 07:47 PM
I didn't do it myself but i believe its the slave cylinder pin length that they cut/machine to adjust the release point. i have a video of them cutting mine.
Old Feb 23, 2014 | 07:50 PM
Whereitsat's Avatar
Ok. Post the video!
Old Feb 23, 2014 | 07:52 PM
stilov's Avatar
stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !stilov Is a GOD !
Seriously. That is my main complaint with my clutch.
Old Feb 23, 2014 | 07:56 PM
Ok. Post the video!
the video provides Zero value to any of you its just a lathe but here is the video they sent me.
Old Feb 23, 2014 | 08:00 PM
Whereitsat's Avatar
You're right. .
But thank you! I'll ask about getting it cut. Who cut yours? I'm in Houston as well.
