Question about changing brake pads
I just got a box of Mintex low dust pads for the street (thanks to Mike at A.W.E.). Is it necessary to replace the vibration dampers when swapping pads? I know you track junkies out there swap pads frequently, so I imagine there must be a way to reuse them.
Re: Question about changing brake pads
No rears available. No date given, but he does keep checking!
So, how about those vibration dampers...can they be reused?
I was able to remove the pads easily without disturbing the vibration dampers. Piece of cake. I guess I will find out tomorrow if there is excessive vibration or squeal!
What did you use to compress the pistons on the calipers?
You can buy a pad spreader. Or if you are cheap like me get a piece of wood about 4" by 12" and 1/4" thick. Once the pads are out slip this in, put it against the pistons and leverage against the rotor.
I used a simple C-clamp. Be sure to check your brake fluid resevoir. If it's full, remove some fluid to prevent overflow when compressing the pistons.
Originally posted by djantlive
vibration damper? is that the shim? if so, I've re-used them before on my previous cars without problem. just clean them up and put on some disc brake quiet grease
http://www.renntech.org/forums/index...iy&code=diy_bp
I read somewhere that you're not supposed to use anti-squeal grease on Porsche brakes. That doesn't necessarily mean it can't be done though.
I've been using same squeel pads for a couple yrs.
I just clean all w/spray brake cleaner...........then I brush on a dab of the goop...shoot, what is that stuff...I've been using the same can for so many yrs I don't recall........I brush it in the center of the flat side of the squeel pad (helps it mate better w/back of the brake pad)........then I just slide the squeel pad down in place.
There's an old DIY over on Rennlist in the archieves or that one on Renntech.
04-28-2022 12:38 AM
2lflat4
11-18-2019 05:05 PM
