2001 Porsche 911 Turbo SQ Audio Build
Old Dec 3, 2014 | 04:27 AM
audioman79's Avatar
audioman79 is infamous around these parts
Old Dec 3, 2014 | 04:36 AM
audioman79's Avatar
New 8" Alpine X0800U installed in dash.
backup camera in action
The HD camera mounted
Old Dec 3, 2014 | 04:40 AM
audioman79's Avatar
The oem battery cables and terminals were replaced with 0 gauge and 4 gauge copper Wire with new nickle plated battery terminals.
Oem cables and terminals.
Old Dec 3, 2014 | 04:44 AM
audioman79's Avatar
We removed the OEM amplifier and made a bracket plate from aluminum to house the fuse holder, distribution blocks and relay. All accessories were attached to the aluminum plate by using screw rivets and screws.
Old Dec 3, 2014 | 04:49 AM
audioman79's Avatar
Next, I began with the amp rack in the trunk area. This is the design I came up with.
Old Dec 3, 2014 | 04:51 AM
audioman79's Avatar
Test fit in the trunk.
Old Dec 3, 2014 | 04:56 AM
audioman79's Avatar
Did some shaping , cut the acrylic trim panel to sandwich with the wood and aluminum.
Old Dec 3, 2014 | 04:58 AM
audioman79's Avatar
Now the amp rack base. Each of the amp rack levels are made of three layers sandwiched together. Red vinyl, acrylic and black vinyl. The acrylic will be lit with multi color LEDS on all three levels.
Old Dec 3, 2014 | 05:02 AM
audioman79's Avatar
Old Dec 3, 2014 | 05:06 AM
audioman79's Avatar
Amps mocked up on the rack.
Old Dec 3, 2014 | 05:10 AM
audioman79's Avatar
All wired up, some minor adjustments for tight fit (massive amount of wires in tight space).
Old Dec 3, 2014 | 05:13 AM
audioman79's Avatar
The false floor panel window was cut out and trimmed.
Old Dec 3, 2014 | 05:16 AM
audioman79's Avatar
finished the false floor panel and grill.
Old Dec 3, 2014 | 05:19 AM
audioman79's Avatar
The false floor and grill wrapped in black carpet.
Old Dec 3, 2014 | 05:21 AM
audioman79's Avatar
