MSS 295/35 235/45 18's
1 Attachment(s)
Really notice the quality of these tires. On KWV3 lowered with rear sway. The extra meat really improves ride, GRIP is great even cold.
Originally Posted by Sourcerock
(Post 4328041)
I believe there is a certain ratio formula that is required to work properly with the AWD, if its not correct sizing there is a potential to burn out the front diff. I know what I'm getting next if this sizing works. Edit; Just checked and they come in 225/45ZR18/XL 95 (Y) , I would have thought these would have been a better match but I could be wrong. Can someone that knows enlighten me. |
(Post 4328041)
Originally Posted by JimTT
(Post 4328054)
Very nice indeed, do you know if these sizes work with the front diff in the awd 996 turbo?
I believe there is a certain ratio formula that is required to work properly with the AWD, if its not correct sizing there is a potential to burn out the front diff. I know what I'm getting next if this sizing works. Edit; Just checked and they come in 225/45ZR18/XL 95 (Y) , I would have thought these would have been a better match but I could be wrong. Can someone that knows enlighten me. 235/45/18 = 26.3" tall 295/35/18 = 26.1" tall 225/45/18 = 25.9" tall The 225/45 would work, but the 235/45 is a better match for the 295/35 with regards to the AWD. I would assume it balances the car better as well providing more grip at the front. |
Originally Posted by vman932
(Post 4328089)
The consenus seems to be that if you are +/- 3% you should not put any additional stress on the AWD diff. However, ideally you want the front tires slightly taller. For the PSS:
235/45/18 = 26.3" tall 295/35/18 = 26.1" tall 225/45/18 = 25.9" tall The 225/45 would work, but the 235/45 is a better match for the 295/35 with regards to the AWD. I would assume it balances the car better as well providing more grip at the front. I find the MSS way better than than the 2's, now I'll have to wait until my fronts wear out which will be 2.5 x rear wear rate, I will then go with the above MSS front and rears. |
I've got about a 500 miles on this setup now. The 26.3"F /26.1"B works better than other combinations I've tried where the backs are 0.1-0.2" larger than the front. With rear sway at full soft I'm having a really hard time activating the PSM.
Over the winter I modified the front radiator brackets, moving the rads fwd 1" and made the cover plate on the back of the front wheel 5/8" thinner. Reshaped the front liners with a heat gun, result is a lot more room. I have a 15mm spacer in the back with no other mods and it doesn't look like I need to roll the fenders. The mods were originally done to accommodate 255/40's in the front when I get to the track but you really need a lot of room for a 26.3"F tire. IMO, the larger profile MSS combined with soft KWV3 setting is more comfortable than stock. The front end deals with the road heaves much better, I think due to both the larger diameter and taller profile. Even with "street settings" and alignment it still turns great. I will take some more pics tomorrow. |
1 Attachment(s)
Fitment pic as requested 11" wheel
1 Attachment(s)
Another angle
(Post 4328120)
I'm assuming the rears fit just fine. I love the way the big rubber fills the fenderwell! |
(Post 4328095)
Thank you for explaining it, I wish I knew this a few months ago as I bought MSS 225 40 18 front to go with my PS2 295 30 18 rears.
I find the MSS way better than than the 2's, now I'll have to wait until my fronts wear out which will be 2.5 x rear wear rate, I will then go with the above MSS front and rears. Here's my analysis of the PSS vs. PS2s....if the tall 235/45 tire clears ok, these #s show the AWD will work as designed. http://i59.tinypic.com/11qtrth.jpg |
I ran into clearance issues in the front wheel well with anything larger than a 25.5" tire on my lowered car. The tire contacts the front part of the liner one side and rear on the other when the wheel is turned.
You can check this on the street and with your current set-up. There are very few prior posts that discuss clearance/fitment with a 26" tire. I did not do any fitment work with the stock lift kit style ride height. In terms of the offset, I found the liner turn clearance is reduced as you move the wheel away from the hub. |
Originally Posted by Road King
(Post 4328943)
I believe you actually made the right call, you want the 225/40s with the stock sized 295/30s. If you had gone with the 235/45s, your front tires would have been a full 1.3 inches taller than the rears!
Here's my analysis of the PSS vs. PS2s....if the tall 235/45 tire clears ok, these #s show the AWD will work as designed. http://i59.tinypic.com/11qtrth.jpg I find the MSS grip better, have a better wear rate and cost less compared to PS2 , so win win. Btw where did you find this graph? |
thats a tall tire---
Btw where did you find this graph? It's a shame that Michelin doesn't make the Super Sport in 295/30/18....a damn shame. |
(Post 4329101)
I simply pulled the data from TireRack and put it in a spreadsheet...then did some calculations with regards to tire height ratio and revs per mile, comparing stock to other combos such as this and the GT2 sizing.
It's a shame that Michelin doesn't make the Super Sport in 295/30/18....a damn shame. Yes tell me about it, can't understand why Michelin would do that. |
Originally Posted by MadWhip
(Post 4329088)
Consistent sidewall height to what you see on track oriented cars like the GTR, Z06 and Viper. |
