Engine coming out
Old Aug 18, 2015 | 08:29 AM
Gunther's Avatar
Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !Gunther Is a GOD !
Engine coming out
I got rear ended and the motor is coming out. Any preventative stuff I should do while the engine is out? I'm getting the cooling pipes done. What else should I do?
Old Aug 18, 2015 | 10:33 AM
BLKMGK's Avatar
Who in NOVA is doing the work, just curious as I'm local too. There's a few threads on preventative maintenance when the engine comes out you might want to search for as they're pretty extensive. Water pipes for sure and lots of rubber along with the coolant tank as I recall are a good start!
Old Aug 18, 2015 | 11:23 AM
rmc1148's Avatar
Agree lots of threads on subject- water pump- coolant reservoir- check clutch the list is endless .
Old Aug 18, 2015 | 11:26 AM
VGLNTE1's Avatar
VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !VGLNTE1 Is a GOD !
Proefi, turbos, rods, lifters, head studs, pistons, 4.0 block, clutch, meth, shafts, coil overs, lca bushings, and gt2rs intercoolers. That should do for now.
Old Aug 18, 2015 | 11:40 AM
Gunther's Avatar
I love it! You write the check and I'm all over it!
The work is being done by Spectrum Collision Center off 4 Mile Run. They do superb work.
I will add the water pump.
Old Aug 18, 2015 | 11:42 AM
uschoice's Avatar
uschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant futureuschoice has a brilliant future
Awsome! Great start.
Old Aug 18, 2015 | 12:10 PM
rmc1148's Avatar
How bad is the accident damage= just being nosey lol.
Old Aug 18, 2015 | 12:16 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Gunter, this should cover almost everything
https://www.6speedonline.com/forums/...hlight=big+fix
Old Aug 18, 2015 | 01:11 PM
Gunther's Avatar
The only visible damage was to the bumper skin and exhaust. But a bunch of crap got cracked or broken underneath.
996Twins that was exactly what I was after! Thanks for doing the hard work and making the list.
Old Aug 18, 2015 | 01:13 PM
996TWINS's Avatar
Originally Posted by Gunther
...Twins that was exactly what I was after! Thanks for doing the hard work and making the list.
The list was easy compared to paying for all the stuff.
Old Aug 18, 2015 | 01:19 PM
rmc1148's Avatar
Good news at least it didn't get into the quarters.
Old Aug 18, 2015 | 03:29 PM
rsvmiller's Avatar
rsvmiller is infamous around these parts
Ecu...
Better replace the ECU Gunther... That is Karma for you! Sell bad parts and you end up on the receiving hand of bad luck!
Old Aug 19, 2015 | 04:02 AM
Gunther's Avatar
No bad karma at all. I'm getting a bunch of nice upgrades. Go back to your sour grapes and negative karma.
Old Sep 16, 2015 | 11:13 AM
996TWINS's Avatar
Gunter, did you get your car back together with some upgrades?
Old Sep 17, 2015 | 12:19 PM
Gunther's Avatar
Thanks for asking Twins!
I get it tomorrow or monday. She needs an alignment and a few other little details finished up. I'm super excited to get her back. She will be a new car maintenance wise. I have not had a chance to data log it after adding an intake and injectors. So I will need to update the tune. But Markski will make that the easiest part of this project.
Once I get her back I will post a few pictures
