Popping sound from shifter when going into 2nd and 4th (997 shifter)
Old Sep 19, 2015 | 10:45 AM
su_maverick's Avatar
su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !su_maverick Is a GOD !
I wanted to see if anyone else experienced this. I installed a 997 shifter a little while ago and I am getting a popping/clunk sound when shifting into 2nd or 4th. The sound is coming directly from the shifter. I am going to pull off the **** and boot to see if anything is hitting or binding but wanted to see if anyone else has experienced this. I did use the alignment tool when I put it on so Im pretty sure its not the cables.
Cheers,
Mav
Old Sep 19, 2015 | 12:40 PM
rmc1148's Avatar
I would do as you mentioned and take a look and see what is binding/loose.
Old Sep 19, 2015 | 12:48 PM
vogz's Avatar
vogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond reputevogz has a reputation beyond repute
Sounds like the cable connection hitting the bottom of the shifter housing. I would take it apart and make sure you got the cables pressed all the way in and the spring loaded retainer seated correctly.
turbotuner20v
Sep 11, 2015 12:02 PM
