New clutch
#61
I'm not sure what data you want? By double clutch/rev-matching the input shaft speed to the desired gear's shaft speed the synchro no longer has to speed-up or slow-down the shaft to mate the gear, it has no work to do and therefore doesn't wear.
Talk to anyone who knows how a manual gearbox works and see what they say...
do you have any data for this claim? the syncros only job is to match the gears together so they don't grind which is what double clutching does. by doing it twice you aren't saving them but actually working them more since they did their job the first time they were engaged.
#62
#64
you don't necessarily need to rev match the final 'step' (engine speed to driveline speed, but you should try) but you are matching the first step/clutching and that's why even non-synchro boxes sync during a shift without crashing gears...this is the whole point of double clutching, to rev match the input speed with the desired gear speed
We may just have to agree to disagree.
Cheers,
Cheers,
double clutching and rev matching are 2 entirely different things. i guess we will have to agree to disagree. after 2 million miles driving straight cut gears with no syncros in everything from a 7 speed to a 18 speed double over to a triple stick mack i think i have a concept of how a manual works
#65
Cheers,
Cheers,
it's an old crash box trick, and should theoretically "work" the same with any manual box.
#66
I have see more than on trans explode using the crash method during track/street racing but yes it can be done and have done it myself when young. I rev match and believe it saves much stress but I see that is another debated subject.
#67
I had a clutch mechanism failure in another car once a couple hundred miles from home. At a stop I started the car, pedal down, in gear, clutch was ENGAGED. To shift I'd let off the gas, pop it out of gear as the driveline went slack, rev it, and drop it into gear as the revs matched - clutch never disengaged. Stop lights were interesting, I'd let the car in front get out then start it in gear and catch up. By rev matching the synchros received minimal wear and I got home. If the two shafts are at the same speed properly things just work but I sure wouldn't recommend it lol!
Vellano Wheels
08-25-2015 02:26 PM
carrera4slakem
08-24-2015 08:14 AM
