What drivability issues did you get from a bad #16 check valve?
So I swapped out a couple of check valves, installed a new throttle body gasket, cleaned and re greased the dv's, and WOW what a difference. I'm not sure exactly what was causing the issue but I'm leaning towards a bad throttle body gasket that someone probably didn't install correctly in the past. I did a few test pulls last night and confirmed 1bar at least twice, where as before I would peak at 0.8bar. Throttle response has improved dramatically as well with no more choppiness at low RPM's.
