Can a VTG turbo be controlled with an EBC or external controller
no, not with 996tt ecu. had been tried with 997tt and plex EBC (linked to the ECU) not a regular BC but much smarter. No need to run VTGs, go for A28, EFRs, GTX line etc.. will get more for less
There has been some vgt controllers developed in the past across different setups. Some of the fist ones were for duramaxes back in 07 when fleece performance created one.
Thing is the cost and the pita to do it is not worth the results. Much better off going with a nice ball bearing turbos.
Option 2 is due a quick spool valve but not worth the effort either on a twin setup in my opinion.
If you want vgt turbos, your probabaly better off just buying a 997
My understanding is they make as much power as an upgraded k16 but with better response and torque curves.
better off getting a set of k24/71hta turbos from srm. zero hassle more power and brand new. without even knowing your price I'm betting its close to the same. even if they are more you can sell yours to defray the cost
I actually talked to protuning freaks about this a few months back and you could actually do it. They are top notch scary smart tuners and best is to contact them but as far as I understood you would need to use an AEM Infinity standalone as it comes with support to control VTGs.
since the vtgs are simply pwm, you "could" find a smart tuner who could adapt the stock N75 map and change the pid constants to get the desired boost, center 2 pins for activating and outer 2 are position sensors that can be ignored. Any standalone with boost control and ability to change these constants would also work. even the ams1000 boost co troller could do this
You'll need a controller (not a complete standalone), that has adjustable PWM frequency -most of them are fixed- and "easy" UI. Then some information how guide vane openings are set in 997 and general understanding of turbocharging... Tuning can be done by trial and error, basically these turbos can be set to full boost from idle (not something I'd recommend, referring to EGT), or as normally aspirated through the whole RPM range. And anything in between.
Then you MUST have EGT sensors, on both turbines' inlets, otherwise you'll melt your turbines.
I still had to try that full boost idle...well, actually not full boost, but abt 0.3-0.4 bar. =) I basically have two settings for boost (toggle switch), one for street with lower boost and progressive curve and the other for track.
if you have the turbos, u should be able to play around on the bench to achieve the desired settings.
