How to lower the motor a couple inches
I'm going to replacing a bunch of vacuum lines and it would be helpful if I had a little extra room up top (diverter valves, venturi tube, etc...) I found this post on how to replace motor mounts and was wondering if its the same process to lower the engine a bit? If so, how much can I safely lower the motor after unbolting those 2 motor mounts?
https://www.6speedonline.com/forums/...-part-nos.html
I'm going to replacing a bunch of vacuum lines and it would be helpful if I had a little extra room up top (diverter valves, venturi tube, etc...) I found this post on how to replace motor mounts and was wondering if its the same process to lower the engine a bit? If so, how much can I safely lower the motor after unbolting those 2 motor mounts? https://www.6speedonline.com/forums/...-part-nos.html
OP: are you replacing with original vacuum lines or aftermarket silicone ones?
Do you know the inner diametre of those and are they all the same size?
I'm slowly compiling a list of hoses that need to be replaced while I'm pressure testing the system. I'm not sure of all the different diameters of the lines and I'm planning of going with OEM lines, however some of the stock lines are $40 for a 4 inch tube with a right angle - no idea why they are so expensive. If there was a complete kit of pre-cut aftermarket vacuum tubes I'd be interested, unfortunately I haven't found any. Most are just spools of vacuum tubing you have to cut yourself. After typing that out, it doesn't sound very challenging to do so. Perhaps there is a kit out there that has all the different diameter hoses needed, then simply cut to length - one by one.
yeah i see from the partslist that there are many molded hoses, but also several of the pipe is standard hose which you can easily cut from a spool (measurements is in the parts catalogue)
But the moulded hoses are probably where the bends are, as a regular hose might bend so it chokes.
With regards to the sizing of those tubes it only says:
4x1.0
and
5x1.0
Not sure what that means, but i guess 4 and 5mm hoses.
The molded hoses are in even other sizes (not stated in the catalogue)
4x1.0
and
5x1.0
ECS Tuning - VW
02-11-2016 12:57 PM
ECS Tuning - VW
02-11-2016 10:58 AM
