Mafless and installing SRM plenum, 82mm TB and their Y-pipe. What check valves....
Old Jun 18, 2016 | 05:43 PM
Enclavet's Avatar
Enclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to beholdEnclavet is a splendid one to behold
Basically the checkvalves should open in one direction only and also at very low cracking pressures, close to 0psia so that the manifold vacuum can provide vacuum to the rest of the system.
Also you need to ensure the valve can handle the pressure differences between the inlet and the outlet to ensure it can hold when under boost.
I plan to use these for those checkvalves when I replace the plenum. They are made of kynar with viton diaphrams. Should withstand the temperatures of the engine bay better.
http://www.usplastic.com/catalog/ite...6844&catid=489
Old Jun 19, 2016 | 11:22 AM
BLKMGK's Avatar
Ah, now that looks like it has potential! Looks like pretty good specs too, please keep us posted if you try them. Might be good to try on a working setup too just to see if they effect operation at all. Billet sounds good of course but I'd wonder if you could find something with as good a spec...
Old Jun 19, 2016 | 12:29 PM
32krazy!'s Avatar
at that cost i ordered 10 of them! w/ shipping it was under the cost of a single pcar check valve. ill install a few when i get the car back
Old Jun 19, 2016 | 12:42 PM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
http://m.ebay.com/itm/5pcs-3-8-10mm-...119?nav=SEARCH
I'm pretty sure this is the style my buddy installed. I recently ordered as well.
Old Jun 19, 2016 | 01:07 PM
Enclavet's Avatar
I looked at those too and the only thing that made me not order those is because they don't specifically say that they are for air. No mention of cracking pressures also or any specs.
Old Jun 19, 2016 | 01:11 PM
I hear ya but I figured he has been running them for a bit now and I want to get away from the plastic. Will see how it goes.
Old Jun 24, 2016 | 12:03 PM
awdbiturbo1's Avatar
awdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant futureawdbiturbo1 has a brilliant future
Originally Posted by BauerR
And other hard-to-reach items should I replace once I'm in there?
Does your SRM plenum have 3 vacuum ports on the top as the factory one does? Mine has two...
Old Jun 24, 2016 | 05:11 PM
32krazy!'s Avatar
its billet aluminum. drill and tap for any port you need. ezpeazy
Old Jun 24, 2016 | 08:45 PM
I know, But was curious if others had two ports and capped the oil reservoir?
tdream1
Jun 10, 2016 09:58 PM
AusTTin Bob
Jun 10, 2016 01:15 PM
ECS Tuning - VW
May 19, 2016 01:24 PM
xmaciek82x
May 17, 2016 11:35 AM
