Notices
Audi r8/rs, gt350 brake calipers
Old 06-23-2016, 12:44 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Been thinking a looking around for calipers and man are they hard to find at a decent price for 997tt, gt3 or pccb calipers. Running 350mm rotors now with 996tt calipers but would like to go to a 380/350 setup for the track.
Well I noticed r8 calipers are somehow cheaper and easy get your hand on. Mounting is similar to the porsche 380mm style rotors so an adapter bracket would have to be made but that is very easy to do. No idea what the piston sizes are on them though compared to the porsche 6 pot 380 calipers.
John I figure you'll probabaly have some insight on this. Worth taking the leap and trying maybe?
Edit: just found that the new mustang gt350 calipers use the same design and are made for 380mm rotor. Brand new they are 650 bucks for a front pair. I know not all brembo calipers are made equal though.
Old 06-23-2016, 05:32 PM
pwdrhound's Avatar
pwdrhound has a reputation beyond reputepwdrhound has a reputation beyond reputepwdrhound has a reputation beyond reputepwdrhound has a reputation beyond reputepwdrhound has a reputation beyond reputepwdrhound has a reputation beyond reputepwdrhound has a reputation beyond reputepwdrhound has a reputation beyond reputepwdrhound has a reputation beyond reputepwdrhound has a reputation beyond reputepwdrhound has a reputation beyond repute
The 380GT3 calipers have 28/30/32 pistons.
Old 06-23-2016, 06:54 PM
flewis763's Avatar
I'll see if I csn find specs on the gt350 calipers because if they are similar, for 650 new you can't hardly say no.
Id probably make the bracket kits to for others if there was interest.
Old 06-23-2016, 07:04 PM
BLKMGK's Avatar
BLKMGK has a reputation beyond reputeBLKMGK has a reputation beyond reputeBLKMGK has a reputation beyond reputeBLKMGK has a reputation beyond reputeBLKMGK has a reputation beyond reputeBLKMGK has a reputation beyond reputeBLKMGK has a reputation beyond reputeBLKMGK has a reputation beyond reputeBLKMGK has a reputation beyond reputeBLKMGK has a reputation beyond reputeBLKMGK has a reputation beyond repute
In for results! Like the look of the Porsche calipers but the prices aren't low! Suspect many will be happiest with 350mm but a nice 380mm alternative might be nice.
Old 06-23-2016, 07:20 PM
pwdrhound's Avatar
If you put 380s on the front in conjunction with 350 rears using the smallish 996 rear calipers, you braking will degrade as the bias will be made worse. You must go with the larger rear 997 calipers if upping to 380 fronts. I tested this years ago. It sucked.
Old 06-23-2016, 07:52 PM
flewis763's Avatar
I do to but actually the gt350 calipers in red match the 997 rear is looks quite a bit.
Also being that they are about 1/3 the price as the porsche ones that's a pretty good deal.
O for sure. 997 rear with these gt350 fronts I think would be a good deal. Would even consider going to a 380mm rear with a spacer on the 997 turbo caliper, don't know if that would shift the bias to much to the rear though.
Old 12-26-2018, 09:51 AM
Fast Ronnie P is on a distinguished road
Hi;
Was there an interest in doing this? I would certainly be interested.
Regards,
Ron
Old 12-26-2018, 09:53 AM
Was there an interest in doing this? I would certainly be interested. Did anyone try to get the GT350 calipers on a 997 non s?
Regards,
Ron
Old 12-26-2018, 11:22 AM
pete95zhn's Avatar
pete95zhn has a reputation beyond reputepete95zhn has a reputation beyond reputepete95zhn has a reputation beyond reputepete95zhn has a reputation beyond reputepete95zhn has a reputation beyond reputepete95zhn has a reputation beyond reputepete95zhn has a reputation beyond reputepete95zhn has a reputation beyond reputepete95zhn has a reputation beyond reputepete95zhn has a reputation beyond reputepete95zhn has a reputation beyond repute
So true. I run now F&R calipers with 380/380 mm discs from 991 GT3. That's most rear biased set one can get with OEM calipers. Works like charm, the best I've had on my car. See piston diameter comparison (in millimeter) below:
997 GT2/3 PCCB F: 32-30-28 / R: 34-34
991 GT3 F: 30-30-30 / R: 34-34
Still, IMO 350/350 disc option with above mentioned bias would be more or less optimal choice for reduced weight track car...
EDIT: I did some googling. Racing Brake sells caliper rebuild kit with pistons: Caliper pistons are 34/36/38 x 32mm height
I would not recommend those calipers to any rear engined Porsche, pistons are larger than in any OEM Porsche caliper.
Again RB also sells rebuild kit for R8/RS4/RS5/Gallardo 8 piston calipers. Pistons are 2x 28mm & 2x 32mm. With a guessimate there's also lot more piston area than in Porsche's calipers. Math later.
Old 02-03-2019, 04:36 PM
Pockr001 is an unknown quantity at this point
I heard Jeep Trackhawk Calipers are also a good choice. 6 piston.
Coloradocurt
04-08-2016 07:21 PM
nvelicu
03-26-2016 11:56 AM
ECS Tuning - VW
03-25-2016 02:33 PM
Quick Reply: Audi r8/rs, gt350 brake calipers
Join 6SpeedOnline
Visit our Sponsors
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
