996TT suspension setup for track/road
what locking ratio/preload did he go with? IIRC, he was building a drag/mile car?
you want that locking preload for chassis stability...while the Torsen/Wavetrac/Quiafe/etc diff works well for Vette/Mustang/fwd/etc cars, the 911's typically do not want a 'free wheeling' diff, again for handling/track setup. Wavetrac would probably do well for autocross.
I'll leave it at that
There is absolutely nothing harsh about a LSD. It's on every Porsche GT and Cup car from the factory. The street units have a very mild preload, less than 10lbs if I recall. Properly set up the Guard unit is seamless even in tight turns. I have a 40/60 unit (same as 6Cup) set up with a pretty heavy preload (about 80lbs) and it's a non issue even when used on the street. Zero noise, zero chatter. If OP is chasing time and looking for the most capable road course LSD, I would recommend a true locking clutch type diff (Guard/Cup/OEMw/Guard guts) as an optimal track choice.
Since the OP is a road course guy looking to optimize his track set up, he needs to simply go to his local track and ask what the fastest 996/997 cars are running. 99% will have true locking clutch type LSDs, period. That's an indisputable fact and in no way meant to knock the highly regarded wave track that many street/straight line guys here are using. They are very good diffs for a different target market.
this is an agree to disagree . heres a video or 2 that shows the capability of the wavetrac. not saying its better just saying its an alternative. not apples to apples but you get the idea
https://www.youtube.com/watch?v=DfBE5U6eRaE
https://www.youtube.com/watch?v=tt4B0wjfDrk
https://www.youtube.com/watch?v=e5RzDcJGDZE
again john im not talking about optimum setup. its clear from the o/p first post he has stock sways, pss10 and mainly does d/e events. i would guess its far from a dedicated track car. with that in mind until he upgrades almost everything he currently has in the car a full lsd would be like running big turbos turned down because you have no fueling. it works but far from optimal. i dont think you started out in a full on track car but upgraded various parts as your skillset and quest for times grew. that being said the half the cost still very functional t/b lsd may be exactly what he needs at his level of performance. once he surpasses that setup a guard may fit the bill.
just my .02 as i never lay claim to being a road racer but see the needs of each sport the same
