Filters on turbos
Old Feb 27, 2017 | 12:20 PM
  #31
BauerR's Avatar
BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !BauerR Is a GOD !
Ultimately, this is what you should see
ID:	470766   Click image for larger version
Old Feb 27, 2017 | 12:28 PM
  #32
SamboTT@ByDesign's Avatar
I would double bag it lol. No loss of flow and more piece of mind/easier cleaning!
Old Feb 27, 2017 | 12:41 PM
  #33
SeattleTurbo's Avatar
SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !SeattleTurbo Is a GOD !
Havent heard the phrase double bag it used around cars before usually only hear that out at the bar
Old Feb 27, 2017 | 02:18 PM
  #34
ccjimmyb's Avatar
ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !ccjimmyb Is a GOD !
Old Feb 27, 2017 | 03:48 PM
  #35
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
I use these. Larger and can get the filter further in and away from the tires. You will need a piece of hose to put over the turbo inlet and the these over that as the flange is 2.438 instead of 2.25
Old Feb 27, 2017 | 03:50 PM
  #36
flewis763's Avatar
Old Feb 27, 2017 | 05:03 PM
  #37
BauerR's Avatar
Originally Posted by flewis763
I use these. Larger and can get the f. ter further in and away from the tires. You will need a piece of hose to put over the turbo inlet and the these over that as the flange is 2.438 instead of 2.25
Those are a better option if your plan is to eliminate the original intake plumbing. I went with the largest filters that would fit that would allow me to keep the original plumbing and be able to go back and forth if needed.
Old Feb 28, 2017 | 08:09 PM
  #38
pteck's Avatar
pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !pteck Is a GOD !
That's actually a great point and that makes me more intriqued. Most of us live in states where smog or an inspection requires us to keep the stock intake configuration.
Being able to switch between the two setups easily would be awesome. ECU tuning is literally a 1 minute flash away beyond the physical filter change.
Old Mar 1, 2017 | 03:37 AM
  #39
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
What pros and cons does a mafless build have.
I know that the maf doesnt work all the time.
Old Mar 1, 2017 | 04:53 AM
  #40
BauerR's Avatar
Absolutely no cons. Wouldn't go back if you paid me.
Old Mar 1, 2017 | 06:15 AM
  #41
flewis763's Avatar
Pros......lots of stuff. Cons........the tune costs money. That is all.
Old Mar 1, 2017 | 10:20 AM
  #42
sinKing's Avatar
sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !sinKing Is a GOD !
What do you guys do with the vent tube on the drivers side?
Old Mar 1, 2017 | 10:36 AM
  #43
BauerR's Avatar
I took off the plug adapter and made my own adapter to push through the rubber front of the K&N. Kind of a rigging but it works. Not even sure its totally necessary, though.
Old Mar 1, 2017 | 12:29 PM
  #44
OK51MON's Avatar
OK51MON is infamous around these parts
Can anyone else chime in on the sound of the car being annoying with a fender intake system?
IM looking to do fender intake on mine and don't want to go through all this hassle of getting a tune etc when it going to sound like garbage even if there are massive performance gains
Old Mar 1, 2017 | 12:33 PM
  #45
BLKMGK's Avatar
Pros? Easier breathing for the engine, better spool, more power. No more blown MAF or MAF restriction.
Cons? MAF is directly measured airflow, MAP is inferred airflow. MAF can adapt, within some range, to higher and lower airflow demands as the engine is modified. Since MAP is inferred changes in airflow capability that change the VE of the setup will require some tuning adjustments.
