Best tire size and spacer setup for Turbo Twist wheels?
Old Apr 4, 2017 | 07:14 AM
machinegunt's Avatar
machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !machinegunt Is a GOD !
Originally Posted by '02996ttx50
gt2 size tires are 18"s..the best sizes are 235/40 X 315/30 ( oem gt2 ) so maybe the question should be: is it worth it to run 19's!? lol...
18's really are optimal for handling and yes, you can run a 315/30 on a stock twist. whether or not you have any liner rub will probably be driving condition dependent. if you are lowered, on 19's you'll rub at hard lock, at the least ( i did anyway..)
but most opt for the 315/30 with the fenders rolled. using a 15 spacer just pushes it out that much more, and its a wicked oem look on stock twists. especially if "lowered". on the plus side it will ride better. not as "harsh" as 19's can be. rolling the fenders is not a big deal and isn't as bad as it "sounds" depending upon the kind HAMMER you use lol
My bad on saying GT-2 size! I meant to say that the 19's I have are the same width being 12" in rear instead of the 11" Turbo twist!
Old Apr 4, 2017 | 07:35 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
If you already have nice HREs I would just stick with those. We have pretty smooth roads here so 19's are fine. Order up some Sportcontact 6 or get some PSS in 295 or 305 if you want sidewall.
Old Apr 4, 2017 | 07:37 AM
brnrdtns's Avatar
If you have 12 inch rears you cant run 295 then. You will have to go 305 or 315. The GT2 325 is too tall.
Old Apr 4, 2017 | 07:47 AM
Tires in 19" are a pain in the *** to find!
Old Apr 4, 2017 | 07:53 AM
brnrdtns's Avatar
Not really, just order Michelins on tire rack or email delticom for Contis.
Old Apr 4, 2017 | 08:25 AM
brnrdtns's Avatar
If you look around for 18's they are getting scarce as well. PS2 production is spotty, Rivals in 315 can be hard to get as well. Yokohama discontinued the 295 AD08. The easiest to get tire with the most plentiful options is the 305 in 19 inch, the same size as the 997 turbo and gt3.
Old Apr 4, 2017 | 08:44 AM
If you look around for 18's they are getting scarce as well. PS2 production is spotty, Rivals in 315 can be hard to get as well. Yokohama discontinued the 295 AD08. The easiest to get tire with the most plentiful options is the 305 in 19 inch, the same size as the 997 turbo and gt2.
Are the diameters close enough on these?
Old Apr 4, 2017 | 08:49 AM
These I'm assuming would be the best match in an 18" rim?
Old Apr 4, 2017 | 08:58 AM
brnrdtns's Avatar
The 245 fronts are a closer match for either option. If you go 305 you can get some really sticky tires like the Bridgestone re71 or the Yoko AD08. The Michelins are probably the best all around compromise though.
Old Apr 4, 2017 | 12:24 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
Like Bernard said, 245/305 on 19 options are plentiful. Tons of tires. Re-71r are insanely sticky and the best 200tw tire for racing street car classes.
Old Apr 4, 2017 | 12:28 PM
flewis763's Avatar
Old Apr 4, 2017 | 08:32 PM
Thanks for the help guys!! I was looking for 245/40/19 and nothing was coming up! Didn't know the 35 would work! Lol!
Old Apr 4, 2017 | 08:41 PM
flewis763's Avatar
a 245/40/19 won't fit and would have been the wrong size anyway
Old Apr 4, 2017 | 10:04 PM
'02996ttx50's Avatar
Originally Posted by HotRodGuy
Overall consensus says 18's
^ exactly. weissach thought of it first.
Old Apr 5, 2017 | 12:36 AM
brnrdtns's Avatar
19's are good, you just need to find the right tire combination. I spent way too much time researching this and explored every option.
If you go with 18's:
Stock 225/40/18 or 235/40/18 fronts along with the 295/30/18 PS2 are best in this size.
GT2 sizes 245/40/18 front with 315/30/18 in PS2 or BFG Rival tires are best.
If you go 19's:
Best fit but hard to get 235/35/19 with 315/25/19 Sportcontact 6 ordered in from Germany are best in this size but low profile sidewalls have rougher ride and less grip. Toyo and Nitto make these but are poor tires.
Next best fit 245/35/19 with 295/30/19 Fronts are .2 inch smaller than rears so front drive may have less efficacy but these are available in many great brands and are very close in size. Won't fit on 12 inch rims though.
Next is 245/35/19 with 305/30/19 Rears are .5 inch taller than fronts which is pushing it, but I haven't heard of anyone ruining their diff with this setup. Lots of rubber on the road and plentiful tire choices. I like the Michelin PSS or new 4S for street tires and the Brigestone RE-71 or Yokohama AD08 are great sticky aggressive tires with awesome sidewalls that will work on track.
