Another catastrophic cooling system failure
#94
Bought an el-cheapo knurl tool for the 90deg fitting, shown below supported by a metric socket.
Thoroughly roughed up and cleaned both male and female surfaces and loaded them up with JB weld
Had a little bit of trouble getting the joint together, used a combo of force, rotating, wood drift, and rubber mallet. Resulted in a nice fillet around the circumference, verified w/ a mirror.
Went on vacation and let it cure for a week. Replaced fuel filter while everything was easily accessible and now buttoning up everything. If I ever need to drop the motor I will go and pin all of them.
#96
They make 45deg ones also. Obv the 90deg fitting won't chuck up in a lathe 😂. So how is your project progressing?
#97
Some people aren't going to want to hear this, but since my hose split rather than a fitting popping out, I think I'm going to pin. I'm a fairly competent wrench, but honestly I'm a little intimidated by the thought of disassembling all of the things required for a weld job. Maybe if I wasn't moving next month I could talk myself into it, but I am moving, and I do NOT want to move my 6TT in pieces. At the moment I have enough time to finish up and get the car back together, if I go much deeper I won't have that luxury.
#101
So, you did it yourself? Pinned them darned fittings and did a clutch? How many hours do you think it took you? and how much $ all in?
I am going to need a clutch one of these days and will pin the 2 on the oil cooler i did not get to and i am starting to plan for it.
I bet it's faster with those new hoses too. I know my car always feels faster after i work on it.
#102
Honestly, A LOT of time and a LOT of money.
I can tally it up fully later but this is pretty close:
Fluids alone are about $200 including oil
Clutch and flywheel were about $2000
If be happy to discuss vendors and prices if you'd like to PM me
Misc specialized tools (triple square socket set, motorcycle jack, right angle drill, 2 more jack stands) maybe $200 more
New belt $60
New 710 diverter valves about $110
So that's $2600 right there...
I also killed both of my hydraulic jacks. So I'll have to get another one of those...
I don't think I'll ever drop the motor on jack stands again. I am already saving up for Quick jacks or maxjax.
Hours are a little more difficult to judge. Ballpark is probably close to 40 over the course of about a month. I used a few cans of brake clean and a quart of purple power to clean and degrease my entire engine, so it looks new. Also had to clean the garage floor because spills are unavoidable.
Hope that helps.
New belt $60
Hope that helps.
