Addl maintenance while engine is out?
Old 06-22-2017, 10:20 AM
FI_FTW's Avatar
FI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond reputeFI_FTW has a reputation beyond repute
What other work/maintenance have you guys done to your car while the engine was out? Just in case I do the coolant lines. Clutch seems the obvious one but I won't need a clutch for a very long time, so that's out.
Anything else that comes to mind? I was thinking fresh coil packs and spark plugs. I have 74k on the clock; stock motor ('02 996TT).
Old 06-22-2017, 11:52 AM
VAGscum's Avatar
These are the things that minimum should be addressed while you have easy access.
Spark plugs
Coils
Pin or weld coolant fittings
Coolant reservoir
Slave conversion
Old 06-22-2017, 06:51 PM
'02996ttx50's Avatar
what is the reason for dropping the motor?
Old 06-23-2017, 12:50 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
Zip tie all pressure lines
Old 06-23-2017, 09:15 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
Water pump.
Old 06-23-2017, 09:51 AM
FI_FTW's Avatar
I may do the coolant lines later this year (preventative).
Old 06-23-2017, 09:56 AM
FI_FTW's Avatar
Originally Posted by VAGscum
Slave conversion
What is the slave conversion about? The clutch slave cylinder was replaced at 60k mi, so probably good there.
How common is a water pump failure?
Old 06-23-2017, 10:14 AM
brnrdtns's Avatar
Common wear part. They start to leak and the pump fins can break off in some cases.
Old 06-23-2017, 10:19 AM
FI_FTW's Avatar
Any aftermarket upgrades? Or just get another OE replacement?
Old 06-23-2017, 06:22 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
Coolant pipe fix
Expansion tank
Water pump
Check valves (I thought there was only one, but there are two)
Oil pressure sending unit
Metal turbo oil feed lines checked
Waste gate vacuum lines
5 bar fuel pressure regulator
Clutch kit
Slave cylinder (found it was leaking a bit with the engine removal. Badnews/good news)
Pressure accumulator
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Throttle body seal
Coil packs
Solenoid brackets
Engine mounts (RSS)
Trans mount (997 version)
Multi-rib belt
2nd gear detent
Old 06-23-2017, 09:16 PM
brnrdtns's Avatar
Just stock is good.
Old 06-24-2017, 06:04 PM
FI_FTW's Avatar
Dang 996TWINS, I'll go broke
Old 06-24-2017, 08:28 PM
VAGscum's Avatar
Haha!
Just rebuilt the car. While you are in there.
Old 06-24-2017, 09:39 PM
wise to do the coolant lines. still not sure that i'd just drop the motor preventatively ( this at 143k miles w fingers crossed lol ) but if i did, i'd replace anything i couldn't reach that was an external part, that hadn't heretofore already been replaced, that wasn't a maintenance item. which btw isn't much. as you surely know, you can get to most all maint serviceable items and all manner of stuff on jack stands. if you do it hillbilly style.
unless i was steve, and had the skill AND time on my hands to drop it for tuesday fun
Old 06-25-2017, 11:22 AM
FI_FTW's Avatar
Yea, the coolant lines may be totally fine; it's just always in the back of my head. Now that my daughter enjoys sitting in the back, it'd be nice to take a few longer trips without worry.
Sounds like the major cooling system parts, all rubber hoses/lines and coils/plugs should be a good start and won't break the bank too badly.
