996tt suddenly has a coolant leak from drivers side rear: 1st post help 🙏🏼
Hi guys,
I am totally stumped as to where this leak is coming from. I hope the Photo shows up since this is my first post on this forum. I have not had any major problems with this car but this leak is stumping me. I have owned this car for about 18 months, and it has been an absolute delight. I hope somebody has had the same spot that would indicate which hose or connection is leaking. Thanks so much for your help in advance and I know there are a lot of threads on this topic but I wanted to detail where the leak is coming from, since there are so many different options for where this leak could be originating .
This is taken from the back driver side behind the back tire. The first sign of leak
is dripping off both sides of a bracket where one of the belt pulleys are.
The belt wheel or pulley that you see below the intake, that is where the bracket sits (under it). The coolant is pooling up there and I cannot find anything higher that is wet. I need mini ninja hands and my hands are not big. Neither are my feet... ****, the trend continues 3/3
Water pump has a weephole in that area, when it fails it leaks from there. Did that a couple of years ago on mine. Not a fun job, but not it isn't the worst thing to do.
As Jayzbird said it could be the coolant expansion tank. Do you find it leaking after you park it and can smell the coolant? That's how mine behaved and it was the coolant expansion tank. Not horrible to change and not really expensive either.
Good luck.
Good luck.
There is a little " puke hose " over in that area for coolant. I put a different exhaust on and I routed the hose a little wrong so it would put a drop or 2 on the cat after driving it. I though I had a cooling system problem because I could smell the sweet coolant smell. I rerouted the hose and now the drop or to that sometime may come out go to the ground instead of my cat.
