Cost for Front Bumper Cover Re-spray? - 6SpeedOnline - Porsche Forum and Luxury Car Resource
Sponsored by: Vivid Racing
Reply
Thread Tools Search this Thread Rate Thread
Old 08-11-2017, 11:31 AM
spooltime will become famous soon enough
When I bought my car over a year ago, the front bumper looked like it previously had a gentle encounter with something, enough to leave a small series of paint fracture lines in the center upper portion of the front bumper cover. Now that my go-fast upgrades are mostly done (they're never completely done), it's time to focus on appearance.
So I took it in today to two different high-end body shops for a re-spray estimate. I told both of them that I would remove the cover, remove the grilles and miscellaneous clips and fasteners, and simply bring them a bare front bumper cover for a re-spray.
It's been a long time since I've had any loose paintwork done at a body shop, but I was little astounded by the two quotes I received. The first one was in the amount of $1,642. I consider this quote to be a f**k you , go away price. The second quote came in at $735. So I need to know if that's where the market is today for a simple paint a front bumper cover job, or if I need to keep shopping.
I'm thinking with me doing the R&R of the cover itself, it ought to be a job in the $350 - $450 price range. But maybe I'm way off the mark. What's a fair price to pay for this work?
Old 08-11-2017, 11:43 AM
HotRodGuy's Avatar
HotRodGuy has a reputation beyond reputeHotRodGuy has a reputation beyond reputeHotRodGuy has a reputation beyond reputeHotRodGuy has a reputation beyond reputeHotRodGuy has a reputation beyond reputeHotRodGuy has a reputation beyond reputeHotRodGuy has a reputation beyond reputeHotRodGuy has a reputation beyond reputeHotRodGuy has a reputation beyond reputeHotRodGuy has a reputation beyond reputeHotRodGuy has a reputation beyond repute
here is one thing I will tell you from many past experiences.
1. You do NOT ever rush a body shop guy.....
2. You generally get what you pay for
3. You don't cheap out on things like body work
While i don't know specifics for the 996. I had the front bumper cover replaced and repainted on my wifes MDX recently and it was around $1,800 with the parts being about $1,000 of that. I would expect about $1,000 to properly respray the front of my 996.
Old 08-11-2017, 11:59 AM
s65e90 is just really nices65e90 is just really nices65e90 is just really nices65e90 is just really nices65e90 is just really nice
$450 is right on the money. Those quotes are laughable.
Source: have worked at bodyshops for some time and I literally just had a well known shop spray my front bumper for $450.
Old 08-11-2017, 12:00 PM
Fortunately, the lower quote is from a Porsche Approved Collision Center, so I'll probably just bend over and go with them.
Old 08-11-2017, 12:08 PM
Slider's Avatar
Slider has a reputation beyond reputeSlider has a reputation beyond reputeSlider has a reputation beyond reputeSlider has a reputation beyond reputeSlider has a reputation beyond reputeSlider has a reputation beyond reputeSlider has a reputation beyond reputeSlider has a reputation beyond reputeSlider has a reputation beyond reputeSlider has a reputation beyond reputeSlider has a reputation beyond repute
Yikes! I have been doing this kind of thing myself for quite a while. I get the paint from a body shop supply store using the paint code under the hood. They have even adjusted the tint because mine was a little off the default colour. I can buy all the paint and clear coat for $100. I usually do 2 coats of colour and 3 or 4 clear coat leaving about 10 minutes between coats (and have paint left over at the end). You do the math - 5 minutes per coat with 10 minutes in between = maybe an hour and a half - call it two for prep and cleanup of the paint gun.
Now, my work is probably not quite up to snuff with a real body shop (I do my work outside) but I would imagine the time is the same. If these guys are charging $1000 per hour, something is definitely wrong. There must be a body shop that would charge for time & materials instead of what you have seen so far.
Old 08-11-2017, 12:12 PM
32krazy!'s Avatar
32krazy! has a reputation beyond repute32krazy! has a reputation beyond repute32krazy! has a reputation beyond repute32krazy! has a reputation beyond repute32krazy! has a reputation beyond repute32krazy! has a reputation beyond repute32krazy! has a reputation beyond repute32krazy! has a reputation beyond repute32krazy! has a reputation beyond repute32krazy! has a reputation beyond repute32krazy! has a reputation beyond repute
why porsche approved? use a quality body shop or in my case i used a high quality hot rod shop with a full paint booth. cost was 600$ for primer body work paint and spray. body guys could care less what the part came from
Old 08-11-2017, 12:35 PM
Stebo's Avatar
Stebo is a splendid one to beholdStebo is a splendid one to beholdStebo is a splendid one to beholdStebo is a splendid one to beholdStebo is a splendid one to beholdStebo is a splendid one to beholdStebo is a splendid one to behold
Every time I ever get body shop quotes, I get the "eff you - go away" price. I'm courteous and never rush them... not sure what's up with that. Good luck man.
Old 08-11-2017, 01:44 PM
VAGscum's Avatar
VAGscum has a reputation beyond reputeVAGscum has a reputation beyond reputeVAGscum has a reputation beyond reputeVAGscum has a reputation beyond reputeVAGscum has a reputation beyond reputeVAGscum has a reputation beyond reputeVAGscum has a reputation beyond reputeVAGscum has a reputation beyond reputeVAGscum has a reputation beyond reputeVAGscum has a reputation beyond reputeVAGscum has a reputation beyond repute
The funny thing is every body shop I have dealt with has asked what type of car even when I want to drop off a bumper of other part to be painted. And they are all on board to paint my silver car parts. Up until the ask the car type and I answer. Unfortunately the Porsche community is fairly saturated with ****y people that makes us known as difficult to work with even when we are not the typical Porsche types. So the prices seem to reflect that.
Old 08-11-2017, 03:06 PM
Quote:
I'm agnostic on that; I just discovered after the fact that one of the shops happened to be Porsche approved - I wasn't seeking one out.
Old 08-11-2017, 03:14 PM
32krazy!'s Avatar
humor me. search out a small hot rod shop with a paint booth. pull the bumper and take in person. theres a half dozen shops around me that would do that without hesitation and wont rape you either. most charge 60$ hr shop rate
Old 08-11-2017, 03:20 PM
jpflip's Avatar
jpflip has a reputation beyond reputejpflip has a reputation beyond reputejpflip has a reputation beyond reputejpflip has a reputation beyond reputejpflip has a reputation beyond reputejpflip has a reputation beyond reputejpflip has a reputation beyond reputejpflip has a reputation beyond reputejpflip has a reputation beyond reputejpflip has a reputation beyond reputejpflip has a reputation beyond repute
I've paid $300.00 and I got a $300.00 job ;-(
Old 08-11-2017, 05:05 PM
gclasse's Avatar
gclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond reputegclasse has a reputation beyond repute
$600 - 700 arena!
Old 08-11-2017, 05:19 PM
Jferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant future
I have paid 300 and 400 each time. Quality work too
Old 08-11-2017, 05:58 PM
drinaldis is just really nicedrinaldis is just really nicedrinaldis is just really nicedrinaldis is just really nicedrinaldis is just really nice
I always assume 800USD per panel here in California
Old 08-11-2017, 09:19 PM
jayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to beholdjayzbird is a splendid one to behold
You don't want just a respray on a front bumper. It will look horrible. They need to sand down/fill all the chips and dings to make it look like new again. I agree the first quote is pretty ridiculous, but it is pretty labor-intensive to do it right.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
