Drop links and kw coilovers
I know this isn't what you asked, but I'd thought it could give you more info. I have KWV1 coilovers, stock front sway with KW supplied drop links. Rear is Eibart adj sway with stock drop links.
Tarret + Ohlins were an issue. Bent the original ones. Tarret is aware of the issue and supposedly will send you a milled spacer for the drop links to avoid bending them. We fashioned our own by the time they came up with a solution.
https://www.6speedonline.com/forums/...g-bending.html
Originally Posted by jdexter
Any idea which version you bought from tarett? They make a bunch of different ends. Can you grab pics sometime?
I already did. They were super cool about it, but didn't know the answer. The guy I spoke with was willing to exchange or return if it didn't fit. That's why I'm trying to find out, less mailing stuff cross country...
I have KW3s and had a nasty spring noise when I turned the wheel with the provided KW drop links installed. I used these (link below) which attach via the through bolt. Looks like they were for sale recently but just sold. https://www.6speedonline.com/forums/...ront-pair.html
