Stereo Headunit Upgrade on the 2002 Bose / Nav Turbo 996?
Talked to CAI and got the info on my upgrade needs. Great guys btw... very helpful.
So w/ the 2002 year, it is prior to the MOST fiber optics as some threads suggest even w/ the Bose setup. However this is one other step to look for if you have Nav... so if you have Nav then you need to check if you have DSP (should be an option in the audio settings where bass & treble are located). If you have DSP then you need to replace the Amp as well.
So w/ my car in particular, I don't appear to have the DSP option so it looks like I can just do a headunit swap. Rod @ CAI said that if I do end up deciding later that I want to upgrade the amp, they sell a kit (https://cai-store.com/collections/99...-amplifier-kit) that will really improve the sound. So I think I'm just going to try out a new head unit first then maybe consider upgrading that later if I want better sound but I don't really want that right now.
Wanted to make sure I shared my experience on the thread in case others are searching for this later.
CAI Rocks. I did my double din with their stuff too. They are very knowledgeable. I’m actually this second doing it in a 2001 that I just picked up. And installing a backup camera. Also just installed home link with auto dimming mirror. I like!!!!
