GT2 Tire Sizes on stock 996 TT wheels no fender roll?
Old Dec 11, 2017 | 03:46 PM
gophaster's Avatar
gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !gophaster Is a GOD !
Question GT2 Tire Sizes on stock 996 TT wheels no fender roll?
Searched a bit but didn't find an answer to this specific question. I know I will need spacers in the rear (I have 8mm, 12mm, 23mm on hand) so that's not an issue.
My question though...is it necessary to roll the fender lips front or rear to run the GT2 sizes on stock 6TT wheels? Anyone running this setup lowered and non-rolled fenders?
Thanks all
Old Dec 11, 2017 | 06:29 PM
Jferrante's Avatar
Jferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant futureJferrante has a brilliant future
The GT2's were rolled from the factory..necessary? I am not sure but not a bad idea.
Old Dec 11, 2017 | 07:07 PM
flewis763's Avatar
flewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond reputeflewis763 has a reputation beyond repute
You can but is almost definitely run on the inner fender liners and rub them through. Better to do a slight roll on the fenders and run a slightly larger spacer.
Old Dec 11, 2017 | 09:48 PM
'02996ttx50's Avatar
it all comes down the the demands you'll be making on the more limited space if you run the slightly wider 315/30 rear without rolling the liners. most any aggressive activity will rub for sure.
even wth fenders rolled i still have rub though, and it's inner liner rear ( with the brackets bent ) and only when bouncing thru tight off camber twists at speed. but no "outer" rub. fenders rolled.
prior to trying both 9x12 and my now preferred gt2 setup of 8.5 X 12 i ran twists with the 7x15 spacers and lowered, fenders rolled. great stance, and look, but i wanted even more plant. so the best bet is 8.5 x 12 imo.
Old Dec 12, 2017 | 01:50 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
I'm running 315's on 19 inch rims, 997 offset 12 inch rims. I had to roll a bit to fit, it is very close on either side.
Old Dec 12, 2017 | 04:27 PM
gophaster's Avatar
Thanks very much for the replies guys. Much appreciated.
Right now im running 19x8.5 and 19x11 with 225-40-19 and 295-30-19 lowered with zero issues. I want to get a new set of PS2's for the stock wheels so I can run those as well. I know its not a big deal but I was hoping to not have to roll the fenders (sounds like it might be possible)..I think I will just order the GT2 sizes and give it a shot. I can try out a couple different spacers and go from there.
Thanks again guys as always
Old Dec 13, 2017 | 06:12 PM
IITURBO's Avatar
IITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to allIITURBO is a name known to all
I'm running 315's out back on stock TT wheels, no rubbing.
Old May 15, 2018 | 10:34 AM
gophaster's Avatar
Just wanted to update the thread. Been running the GT2 tire sizes for a few months now (on Sport Techno wheels at 18x8 and 18x11). My fenders are not rolled and no issues.
The Sport Techno wheels are different offset vs the standard twists so Im running spacers on them. Effective offset in the rear is 37mm.
Couple pics for reference :
Old May 16, 2018 | 04:46 AM
ghostofpain's Avatar
ghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to beholdghostofpain is a splendid one to behold
the ET40 offset on the front can be a probleem, when your car is lowered. So rolled fenders on the front are a good thing.
On the rear it isnt neccesary. Just the fenderliner on the inside can be a problem, so the 996 GT2 brackets can help out there.
The pic shows the GT2 wheel size on my car with Toyos. On the rear i got 5mm spacers.
csufl
Cayenne 958
Sep 29, 2011 01:02 AM
Brando
Track & Autocross
May 20, 2009 04:23 PM
itacud
Jul 16, 2008 01:55 PM
