Best “filter on turbo” setup
Yeah been in London like 10 times already, also Birmingham and some small cities in the area. Aquamist is a game changer for our cars, syvecs would be even better than plex, but might not need it, maybe can put those money into something else as plex is really a great product
Nice, I’m about 12 miles outside Birmingham but the weather is no better here I intend on doing the Syvecs at a later date but so far it seems it’s circa Ł4000 for the ecu without mapping! I have heard lots of good things though. It will probably be next winter along with rods and head studs.
The cloth filters don't clean as well as paper, that is how they flow better, they let more through. Pre filter covers help.
CATIA. I used a FARO laser scanner. The scan as-shown isn't very good as I wasn't actually trying to capture the suspension at the time.
The thing is that these are designed for the By Design/Tial K16-68mm turbos on my car. So it would also work for stock turbos since the compressor housing doesn't change. For something with a different compressor housing, the design would have to change, and I'd pretty much need to scan it. There is very little space to work with and it needs to be positioned very accurately in order to not have interference.
The way I designed these, a short length of 3-ply silicone tubing is slid over the compressor inlet and then this clamps onto that. That isolates the adapter piece from the compressor housing which heats up to about 200F from what I've seen (I put temperature labels on the inlet to see the max temps it reaches).
Ok, well, I’ll be using tial 3076 turbos which will hang in the same place but will have different in sizes I’m sure. Is it that tight in there? Could this be dealt with via the silicone hose?
I have 997TT airbox setup with do88 inlet pipes that I am going to have back together in my car soon.
On top of everything the 997s have to do to run the emre box, youre going to need to change a lot of other things than just the airbox and inlets to do it- not a direct bolt in. Need 997 y-pipe, 997 ac lines, 997 style fuel cooler and refrigerant lines for the fuel cooler (or delete the fuel cooler and use the OEM 996 GT3 piece that replaces fuel cooler in those cars). 997 y pipe needs larger throttle body from the 997, so need a different plenum to fit the larger throttle body. Also with 997 y-pipe you lose your diverter valve plumbing spots that 996 ypipe has since the 997 diverters are on the turbos- so you have to find a way to relocate and custom plumb in your diverters or get metal intercoolers that you can weld BOV flange on the end tanks since the BOVs won't fit in the traditional spots on the y-pipe with the 997 airbox installed, etc etc.
Doable- yes. Easy- not really. Cheap- hell no. Best bang for buck is filters on turbos. I also live in a rainy climate so I am hesitant to do that, plus I track car a lot and I'm just not comfortable with the filters down low in case I have an off and lose a filter and suck up some of the dirt/grass/rocks swirling around under the car
https://www.knfilters.com/mobile/mPr...x?prod=RF-1031
these. You will need to check the housing inlet size for you 3076s, but these fit my 3073s perfectly. The 10deg angle allows you to tweak to miss the suspension and tuck them in tight near the axle.
Then add these.
https://www.knfilters.com/mobile/mPr...prod=RF-1035DK
Then add these.
My car ran and my brothers car currently runs the Blitz SUS Filters (C4 Core) but the A3076 compressor cover is too small to fit them. With 6466 and my Xona 95-67's we have to run a piece of 4" silicone coupler on the turbo inlet for it to fit though.
Some of the K&Ns will work good as well since you have the smaller compressor inlet. Just be careful on rainy/wet days when running filters on the turbos.
Doing pipes that go into the fender wells (above the IC) will easily support 1000-1200rwhp with no issue. Plus you are protected a lot more from water on the road, etc. I ran that setup at my 1050rwhp GTX35 setup for a long while. My brother on his A3076 stock motor setup ran the same thing as well. When I went to the 6466's I got the Blitz filters, and now that my brother has my 6466's his car runs the Blitz Filters
