BC Speed Fest 1/2 mile results! Thanks Sambo
Attended the Battle Creek Speed Fest 1/2 mile airstrip event last weekend. It’s a unique 1/2 mile event because you run in the morning, break for lunch and get to watch air show, which was awesome. Then run in the afternoon again if you want. I didn’t run in the afternoon (not my choice, lol...details below).
First I have to give a big shout out to Sam@bydesign for pretty much always being available to answer my questions/concerns and for awesome tuning/support.
Over the last year or so I’ve been trying to stretch the OEM K16s as far as they can go. I started with a Mafless tune from Sam using the Cobb AP, and added 997GT2RS intercoolers, Speedtech 2.5in X-pipe with 100 cell cats and a 5bar FPR. Ran some 1/4 mile passes last fall and was able to rip off an 11.6@123mph on race gas. Not bad, but I was leaving some power on the table with the rusted factory wastegate actuators. I couldn’t tighten them and was thus only making about .8 bar up top.
So this summer I picked up some Tial 1bar WG actuators and Forge DVs from Sam and he re-tuned to squeeze as much as we could out of the factory Turbos. Now I spike to 1.2 bar and hold 1.1 bar all the way up to 7k rpms. Car feels a lot stronger.
Conditions were pretty rough for the 1/2 mile last weekend. 90+ degree heat and a very stiff headwind of almost 20mph. Some very powerful cars were running much slower than normal. My best pass was 151mph. This was a standing start too. No rolling from 40 here.
To compare with other cars at the same event.
2018 R8 V10 with exhaust - 150mph
2008 GT500 with 620rwhp - 146mph
2012 Mustang GT supercharger with 730rwhp - 153mph
2014 911 Turbo S with tune and exhaust - 154mph
Car is flying for stock K16s. In good conditions should be able to trap 128+ in the 1/4.
Alas, I might not get to find out since I popped a coolant fitting on my third pass right before the line. 🙁
If I need to pull motor to get to whatever fitting popped I’ll probably upgrade the turbos too.
Anyway, check out pics here!
https://goo.gl/PeUY7a
Thanks!
Found the cuprit.
https://www.flickr.com/gp/153274489@N02/Ma60dF
I think I'm going to JB weld it back in and then pin all the accessible ones. while I'm in there. Should be back on the road soon.
Clutch is actually holding up really well so far. It was replaced shortly before I bought the car in 2015. I can launch hard and shift hard with zero slip.
That said, I'm probably going to pull the drivetrain over the winter for turbos, injectors and clutch.
Found the cuprit.
Thanks for posting, lots of good info. Pics?
I'm also running a Sambo 1 bar MAFless Cobb tune with Kline "offroad" exhaust exclusively on 100 octane. Car holds 1.0 bar in cooler weather, but I would also like to squeeze a little more out of it, maybe ICs and some wastegates will yield a little more...
The extra boost is definitely very noticeable.
do it...and turbos
Do it, and then get some WG actuators and FPR. I was running out of fuel BEFORE the new WG actuators.
Yeah, Sam told me to tighten up the arms, I left em. Fast enough for now, and the 3" catless with a ton of other mods does help the boost and spikes a tad. I agree that a pump, injectors would be the next step, just enjoying the car done as is. IMO for the street, there's no reason to need anything more. From your times, it's flying.
Definitely
CarpeTTS
New Member Introductions
07-26-2018 04:18 PM
dhahlen
07-14-2013 02:46 AM
basupra
12-17-2009 03:09 PM
