Durametric Log Parser
I'm working on a wot logs parser and also making it compatible with any log format but will require that you include either load or throttle to determine the WOT runs.
If nothing shows up for your log just message me with the URL link that I generated and I will look into it. URL: https://logs.enclavenet.com/ Github: https://github.com/Enclavet/logsparser/ Changelog: 10/24/2018 - Added correction factor for boost control from knock control overlayed onto timing and boost graphs. Showing knock for durametric logs. 10/17/2018 - Added graphs for knock overlayed onto the timing graphs. Added MAF graphs. 10/16/2018 - Added initial support for AP logs now as I saw someone upload 2 of their logs. Log formats: Durametric Accessport Graphs: IATs Inj Duty Cycle MAF Act Boost vs Req Boost Timing vs Knock Lambdas Requirements: Logs must be in CSV format with the correct titles describing the data. Must include Load or Throttle (TPS) Examples: https://logs.enclavenet.com/?logtype=0&logfile=./uploads/5bc3ae1fca93d.csv - Durametric log of my K24 Mafless 80lb 1.2bar tune. https://logs.enclavenet.com/?logtype=1&logfile=./uploads/5bc7314bcdc41.csv - Accessport log for a log I found on the forums. Shows knock retard versus timing. Graphs of key data are automatically generated from the detected WOT runs: https://cimg4.ibsrv.net/gimg/www.6sp...ac5fbaf402.png https://cimg3.ibsrv.net/gimg/www.6sp...915675c2ae.png |
What's the parser written in? Would love to collaborate if you're interested.
PHP and javascript/jquery.
Will probably put it on github so you check out and make changes if needed. |
