-   996 Turbo / GT2 (https://www.6speedonline.com/forums/996-turbo-gt2-2/)
-   -   When I get my 19's is the correct tire size... (https://www.6speedonline.com/forums/996-turbo-gt2/42672-when-i-get-my-19s-correct-tire-size.html)
Griza Feb 16, 2006 02:34 PM
235/35/19 and 315/25/19 for the PS2's? Is there any rubbing issues? My car is dropped on Ruf PSS9's. I do not know what setting it is on but it is not overly stiff and I have like a 1-1 1/2 finger gap between tires and fender.
I have decided on the Iforged Aero's. I personally like the clean 5 star with rivets, a black center and polished lip...........:cool:
damon@tirerack Feb 16, 2006 02:51 PM
Size sounds good! Give me a call to order.
Griza Feb 16, 2006 03:51 PM
Damon,
What are your thoughts on the new Conti VMax??? They look interesting.........
Klint Feb 16, 2006 05:15 PM
Negative on the contis.
Griza Feb 16, 2006 05:21 PM
Even the new VMax? They just came out I think. They are not the regular Contact2's............
vipertestarossa Feb 16, 2006 08:48 PM
Griffin...
PM sent
GreggT Feb 16, 2006 09:23 PM
Rubbing issues?.........what's the offset?.......are rears avail in 11J?
Griza Feb 17, 2006 10:58 AM
I was asking if there are any rubbing issues. I am not sure what the offset is, I will find out. They custom make the rims so I am sure they can make the rear 11"
GreggT Feb 17, 2006 01:37 PM
If they are "custom".....then they can be any offset you want.
Offset determines where wheel & tire sit (in-out) relative to wheel arch or fender line so it's the main (of 3 things) that affects clearence('rubbing issues')....the other 2 things being ride height, and finally wheel/tire size.
People who are real picky about looks (and where that outside edge of the wheel & tire sit relative to the car body) are 1st deciding on offset......(that's after they decide what tire they want the rim to eventually hold) :D .
Getting all this bass-ackwards can, sometimes, produce less than optimum results. :)
Griza Feb 17, 2006 02:24 PM
I agree and I don't want to spend the money if it is not going to be perfect. I would like to have the wheel and tire be flush with the body but I would rather have no rubbing if I had to make a choice.
I bought my car with the suspension already on there and I have not measured the ride height. Iforged has done rims for quite a few dropped 996TT's, I would imagine they will know what to do. I estimated the drop to be 1-1.5" whe I placed the order.
Do you have a rough idea of what parameters will cause rubbing or do I have enough clearance to run this size rim and tire without to much issue? There are quite a few people on here that run this size tire and they are dropped/modded so I would imagine there is some room to pplay with. Thank you for the info, I appreciate it........:cool:
DeeMan007 Feb 18, 2006 12:35 AM
How do you find out the factory offset for the wheels or the optimum offset for 19" rims?
bowmanm98 Feb 18, 2006 12:53 AM
The aeros are my favorite too. Let's see some pics.
Griza Feb 18, 2006 08:09 AM
I just ordered them two days ago. It will take 4-6 weeks minimum before I even see them...............
gsc Feb 18, 2006 08:32 AM
You;ll love the Aero's. Great quality wheels.
Griza Feb 18, 2006 09:31 AM
Yes, they are great. I had a set of 19's on my S4. I have not found another set that I like more...............
