my 996 future build list
https://docs.google.com/document/d/14STiz1--WsdR8Tz9bP4o-cVEMoK9_iTGcDBIugvJbxM/edit?usp=drivesdk
Im sure I forgot something or some of my parts aren't as good as I think they are. Please give me all the suggestions and comments on how to make my built better or anything I forgot.
wow - you should all all this suff installed by monday. How are you using the car ?
for intercoolers - If on the track and extended time use tube and fin. Call Sonnen Porsche. you will have some plastic trimming and install work... search the site for more details:
Otherwise search the forum... lots on this topic... good luck
997.110.639.70 Left Intercooler - 99711063970 <- 71 replaces 99711063971 –OEM - sonnenporscheoemparts.com
997.110.640.70 Right Intercooler 99711064070 <- 71 replaces 997-110-640-71 –OEM - sonnenporscheoemparts.com
If I were you, I would pick a tuner, and have them spec the parts based on your power goals. Typically they have experience with parts needed to make your power goal. People rave about Marski, Sambo to name a couple. You will be much better off in the long run, and will have a setup and parts that are proven to work together to meet or exceed your power goals.
Just my opinion, good luck.
You have a mix of parts and quite a bit of it doesn't make sense. We can help you but a few questions first.
1. Where are you located?
2. What are your goals for the car?
3. What is your budget?
agree. some parts needed, some less so. you need advice of a tuner that has done this a thousand times.
i have similar 16/24 hybrids and the same evoms DV"s and the ipd plenum etc. they key is ( as others say ) matching parts, to tuner to tune etc. its not enough to just buy stuff.
imcarnuts
07-23-2012 09:10 AM
G ZILLA
Mid-Atlantic
20
03-08-2012 10:37 AM
