Immobilizer??
Old Mar 20, 2019 | 06:04 PM
gadangit's Avatar
gadangit is a name known to allgadangit is a name known to allgadangit is a name known to allgadangit is a name known to allgadangit is a name known to allgadangit is a name known to all
Immobilizer??
So my car just quit while driving. I've chased down everything I can find, replaced the clutch switch, voltage regulator and battery. In my journey I discovered that possibly my key or immobilizer/signal converter has gone haywire. What to do?
Old Mar 21, 2019 | 08:39 AM
Macster's Avatar
"This fault is displayed for information purposes, it is not an indication of a problem and no repair is needed."
What makes you believe the immobilizer/signal converter is at fault?
Old Mar 21, 2019 | 08:46 AM
gadangit's Avatar
My car won't start. And this screenshot under immobilizer. The battery checked out as "okay", but was replaced because it was 4 years old. The alternator checked out as "fine", but I replaced the VR just in case. The car literally just quit while I was driving, no warnings, no nothing and refused to start. I am open to almost anything at this point. Does anyone else's durametric show the immobilizer as active??
Old Mar 21, 2019 | 08:49 AM
s65e90's Avatar
s65e90 is infamous around these parts
First post almost looks like the interior sensor for the alarm causing the no start but not sure. It has happened before. I believe they are just microswitches that go bad. Doesn't make sense though as you were driving the car when it shut off.
Old Mar 21, 2019 | 09:01 AM
gadangit's Avatar
I'm not sure that the signal converter is bad, I am suspecting that there is a fault associated with the alarm control module.
Old Mar 21, 2019 | 09:45 AM
gadangit's Avatar
This post kinda sums it up. I do have a new aftermarket radio that was just installed a few months ago. Skip to the last post to see the synopsis.
http://pedrosboard.com/read.php?7,19513,19553
Old Mar 22, 2019 | 09:00 AM
gadangit's Avatar
I'm going to flatbed to Porsche dealer as opposed to independent. I hope I don't regret that.
Old Mar 23, 2019 | 07:48 AM
eds996tt's Avatar
eds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of lighteds996tt is a glorious beacon of light
Hass, this is a good idea to bring to dealer at this point. Some things are beyond our vision with regard to complete end to end diagnosis.
Let’s see what they say… Good luck..
Old Mar 23, 2019 | 08:24 AM
wross996TT's Avatar
So you have looked at fuel? Fuel pump or ruptured hoses in the fuel tank?
Old Mar 23, 2019 | 08:31 AM
gadangit's Avatar
Never got that far, car wouldn't engage the starter.
Flatbed arrives in 30 minutes, I'm going for a sail today to give this a rest. I'll know more on Monday.
Chris
Old Mar 23, 2019 | 11:28 AM
Slider's Avatar
Those would not stop the starter from turning the engine over - they would just stop the car from actually starting.
Old Mar 24, 2019 | 09:24 AM
wross996TT's Avatar
The first post said his car stopped while driving. What's that got to do with the starter?
Old Mar 24, 2019 | 12:07 PM
gadangit's Avatar
Durametric says Immobilizer Active. I'm assuming it is supposed to say Inactive, but never looked at that before. Obviously the immobilizer won't allow the starter to engage. At this point the fuel pump is an unknown, but it previously worked with no issue. We will leave it as unknown for the time being.
The bigger question is why did the car just quit while I was driving it. All systems were normal until they weren't. No fault codes, no dash lights, just the car coasting to a stop. Hopefully the dealer will shed some light on Monday.
Old Mar 24, 2019 | 06:23 PM
s65e90's Avatar
Sounds similar to possible fault of the alarm modules inside the car. Usually the car is parked and then won't start, odd that the car died and then/now this. GL
Old Mar 24, 2019 | 11:16 PM
Slider's Avatar
He also said that, now, the starter does not turn over when he turns the key. So, fuel could be a reason for the car stopping - yes; but that could not also be the issue with the starter not turning over. The final solution should be to address the issue that would be common to both of the symptoms.
