Pros and Cons: K16 Turbos Vs. K24s Turbos
Old Nov 18, 2006 | 02:13 PM
JWC's Avatar
JWC
JWC is infamous around these parts
Ramone one of the tuners on here can answer your questions better than I can. But I am new to Porsche and purchased a 02 w/ the X50. It was stock and a Tip. at that. I now have Hybrid K24's (Protomotive) and supporting equipment and the lag is less than it was with an 01 with the K16's I test drove; not to mention the huge power gains I enjoy now. I think you should take the expert advice given by sharkster ask around and but your butt in a few set ups and see what you like best.
Old Nov 18, 2006 | 02:39 PM
ebaker's Avatar
ebaker is infamous around these parts
Originally Posted by WOODTSTER
Oak,
what is the difference between Hybrid and GT1
MK
The GT1 is a hybrid with a standard K16 turbine and standard K24 compressor.
Old Nov 18, 2006 | 02:40 PM
TKDalumni's Avatar
TKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really niceTKDalumni is just really nice
ebaker's right. It works for me!
Old Nov 18, 2006 | 02:42 PM
K24madness's Avatar
K24madness is infamous around these parts
Originally Posted by ramone
So basically this is what I've understood so far....
Hypothetical Situation
K16 Car running (500hp/520tq)
vs.
K24 Car running (500hp/520tq)
Results:
K16 Car is faster at low end speeds
K24 Car is faster at highway speeds
K24 hybrids > K16 Hybrids
Stock K24 > Stock K16
Hybrid K16> Stock K24
Understand? You want K24 hybrids!!!
Old Nov 18, 2006 | 04:33 PM
K24s hybrids are the way to go... just look at Divirexxtreme 10.6 sec. run at 136 mph.
There are a pair of these turbo set ups running around in NY area... and they beat the stage 4s they came across relatively easy...
Not starting to bash but thats the truth. Just ask William.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 18, 2006 | 04:49 PM
TKDalumni's Avatar
K24 Hybrids being 24/26's?
Old Nov 18, 2006 | 04:56 PM
yellowturbo's Avatar
yellowturbo is infamous around these parts
Protomotive favors K24/18g hybrids.
Old Nov 18, 2006 | 05:21 PM
K24madness's Avatar
K24/18g hybrids are are a better combo than K24/K26's. The size of the 18g compressor is better suited to the 3.6ltr motor running the boost levels we do.
Old Nov 18, 2006 | 05:26 PM
Actually the k24/18g is not the only way... some stuff the garrett gt30r compressors as well. Others liek Kevin do their magic too. The whole point is that k16 housings are too small o produce any meaningful power( relatively speaking)...
9.66
click to view
Old Nov 18, 2006 | 07:58 PM
ramone's Avatar
ramone is infamous around these parts
I don't understand this "hybrid" stuff
Do you modify the K16 Turbo itself or do you have to buy a whole new turbo setup called a "K16 hybrid" ? Is this a simple mod ? How much are these things ? What are the advantages/disadvantages ? What kind of numbers does a "K16 hybrid" push ? Is this only for extreme setups ie. 600hp plus ?
incase you hadn't guessed it, I'm a newb
Old Nov 18, 2006 | 08:31 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
kevaaaaaannnnn where are you???
Old Nov 18, 2006 | 08:35 PM
Turbo Fanatic's Avatar
Here is a basic simplification:
Every turbos has 2 "fans". The one in the exhaust is called the turbine, the one in the intake is called a compressor.
You can mix and match turbines and compressors from different turbos to get different results.
Old Nov 18, 2006 | 08:39 PM
600HP and below aren't 'extreme' setups on this forum
In fact, a regular x50 with a flash and exhaust gets pretty close to that 600HP number (to the flywheel not to the wheels). Anything over that requires a little bit more (such as better fuel delivery, etc.).
Changing to turbos other than the stock k24 or k16 requires a bigger investment which can be rewarded in more efficiency (higher HP at the same boost levels) and less lag.
Old Nov 18, 2006 | 09:42 PM
willcoxmd's Avatar
willcoxmd is infamous around these partswillcoxmd is infamous around these parts
Marski is the real deal, i'd listen to him. I have tweaked my X50 a bit and I feel very little lag. I'd go with K24's
Old Nov 18, 2006 | 09:50 PM
KPG's Avatar
KPG
KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !KPG Is a GOD !
Who is Markski sorry couldnt resist!
