My Protomotive Monster is done: 871 rwhp@1.5 bars
Old Dec 9, 2006 | 08:26 PM
  #211
iLLM3's Avatar
Originally Posted by MARKSKI
Scott I took some bolts off ur motor. Lol it was on the table near cynthia hehe
LOL you should have taken some parts off and sent it to me like i asked :P jkjk!!
Mark glad you and that ANIMAL got home safe and sound, car is such a beast Im going to call you tomorrow!
Old Dec 9, 2006 | 08:31 PM
  #212
JR. chicago will be terrorized this summer... LOL
Martin, OMG I cant believe..... guess waht Im on .6 bars of boost only....
Im going to take some sound samples and video.. just as soon as we warm up....
Martin this is Crazy... no joke.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Dec 9, 2006 | 08:37 PM
  #213
Brian Haske's Avatar
Brian Haske is infamous around these partsBrian Haske is infamous around these parts
You should mix some music with the videos and sell it on your website
Old Dec 9, 2006 | 08:43 PM
  #214
iLLM3's Avatar
im so jealous dammit, you make me realize I NEED BOOOOOSTTT
Old Dec 9, 2006 | 08:48 PM
  #215
mt72's Avatar
mt72 is infamous around these parts
Actually you got only one thing correct.....
here:
2004 WORLD CUP CHALLENGE CAR HEAD (RACE CAR)
GT3 STREET CAMS
LOWER END REDONE STILL 3.6 LT.
Alot of work went into retrofitting gt3 cams into this head... custom cam and piston hold down tools had to be made. Also the O ring grooves to prevent the head from popping.
car is running on GT3 street software... No vario cam 8200 rpm
thanks,
markski
Hey thanks for the quick answer .
2004 WORLD CUP CHALLENGE CAR HEAD USE WHAT ENGIN IF I MAY ASK
When you say GT3 software doe you mean ECU USB PLug and play engin Management ? Sorry to keep asking question but since the cat is out of the bag min't as well
Old Dec 9, 2006 | 09:06 PM
  #216
I would have to ask Todd... we only had the head sent to us from germany....
Ist a gt3 RS head I believe...bit the race version ... Im not sure I have it somewhere in my email. It did come from a 2004 world cup challenge car.
Todd programmed the motronic with the GT3 street software. He even managed to write in PSM and ABS.. soemthing not standard on gt3s not gt2s...
markski
9.66
click to view
Old Dec 9, 2006 | 09:17 PM
  #217
mt72's Avatar
markski
That's very impressive to rewrite the software for PMS & ABS ....
SO Todd swaped the gt3RS on 996TT botom end
again congrats on the projet mad props 2 U & Todd
Old Dec 9, 2006 | 09:21 PM
  #218
cjv's Avatar
cjv
Moderator
It uses a 996tt ECU with GT3 program. It requires a boost controller, manual boost gauge and new ABS program. That is over simplifying it as the values all had to be re written
Old Dec 9, 2006 | 09:33 PM
  #219
cjv's Avatar
cjv
Moderator
markski
Markski,
I do not remember what heads you incorporated. If they cam from a Cup car then they are probably Cup heads. There are four types. The turbo heads have smaller ports and valve sizes are 32 and 35 mm. Then you have GT3 street, GT3 World Cup or Cup heads and then GT3R heads. I do not know the spec on the GT3 Street heads. The GT3 Cup and R heads have the same ports . The valves on the Cup heads are 35.5 and 41.0 mm while the R heads are 36.4 and 42.0 mm.
Old Dec 9, 2006 | 09:45 PM
  #220
cjv's Avatar
cjv
Moderator
Judging from the pics Markski provided, it appears Todd used stock turbo pistons flycut to clear the valves. The turbo, GT3 street, GT3 Cup and GT3 R motors all have different pistons and rod lenghts. The wrist pins on the GT3's are narrower in diameter than the turbo wrist pins. Markski, do you know what rods (as in manufacturer were used.) The crank cound be either a turbo or GT3 crank. Do you know what was used?
Sorry about all the questions ............... if info isn't known, no biggie.
Old Dec 9, 2006 | 09:47 PM
  #221
VRAlexander
Guest
Posts: n/a
Or you can do a custom head and fit 38mm and 44mm Valves and flow 368cfm's .
Old Dec 9, 2006 | 09:49 PM
  #222
cjv's Avatar
cjv
Moderator
You mean turbo heads ported to GT3 type specs and valved for 38's and 44's. Now Alex, you definitely have bigger valves than Markski ............. but Markski has a bigger stick.
Old Dec 9, 2006 | 10:05 PM
  #223
mt72's Avatar
Swaping the head most of been a big chalenge for clearence issue but the oversize valtrain certainely helps alot in the flow of the beast
Old Dec 9, 2006 | 10:14 PM
  #224
dgussin1's Avatar
dgussin1 is infamous around these parts
that is a whole lot of flow! What do stock heads flow?
Old Dec 9, 2006 | 10:18 PM
  #225
cjv's Avatar
cjv
Moderator
Actually, the heads bolt right on. The big advantage of the GT3 heads is the GT3 cam housings and the GT3 intake manifolds. Markski used GT3 cam housings and turbo intake. The challenge with the heads is making sure your pistons have enough clearance and enough strength after you flycut them. That is if you use the stock pistons. The GT3 tappets are smaller and lighter and believe it or not depending on the type of cam being used (street, Cup, R) and year, they are all different (solid, hydralic, flat or radius toppped). Each one uses a different valve stem length. In addition Porsche made dimensional changes between some of the years.
Promotive's real coup is the ECU. No one to date has made a GT3 turbo motor with a GT3 cam work with the 996tt ECU. The turbo has 5 cam pointers, GT3 street 3 cam pointers, Cup and R one cam pointer. The different ECU's don't start and operate with different cams. This is what had us stumped for months. Todd is a real genius.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
