Attn: 6speeders..any words of wisdom for me? changing my dv 's
Old Feb 21, 2004 | 07:58 AM
MWM's Avatar
MWM
MWM is infamous around these parts
Smile
Do yourself a huge favor and have some warm, soapy water for the "male" ends of the new DV's to slip them into the hoses. One in particular sticks out in my mind. I think it was while attaching the paired DVs back into the motor --- one hose down low stays attached.
I wasted a lot of time trying to shove that last connection home. Give it a touch of non-rubber-eating lube (like soapy water) to slip it in . . .
Old Feb 21, 2004 | 11:01 AM
DrJim's Avatar
DrJim is infamous around these parts
Originally posted by sporters78
Ok red devil ,i'm going to ask... how do you know about making a gauge in the rubber hose?
Easy, I tore the hose trying to remove those **** clamps. Due to some shipping mishap, I ended up with 2.
Old Feb 21, 2004 | 03:38 PM
PorschePhd's Avatar
Just a dot of dish soap works well too. Just place it on your finger and smear it in the inside of the hose.
Old Feb 21, 2004 | 05:07 PM
Slate TT03's Avatar
Slate TT03 is infamous around these parts
Thumbs up Installing DV's
Just installed the Bailey DVs in my car following the instructions from AWE tunning. It took about 1 hour and 45 min. I used lockable needle-nose pliers to hold the factory clips compressed while pulling hoses and DVs out. I found that compressing the bottom clip of the front (deeper in the engine bay) DV is easier if you remove the F-type hose (connected to the side of the DVs) completely out first. This clip (as many others indicated is facing to the front of the car) so the only way to grab it was to twist the bottom rubber assembly (where the bottom of the DV's is connected) towards the back of the car and it was much easier when F-type hose was removed first.
I hope this helps.
Paintballzen
Oct 10, 2020 12:22 PM
Rguy
Apr 12, 2020 11:11 PM
Christophosphorus
Sep 2, 2015 12:40 PM
MC36
Southeast
Sep 1, 2015 06:39 PM
