Official Turbo Weight Loss Thread/ Lightest Turbo List
Rating: Thread Rating: 4 votes, 4.75 average.
  #781
Old 04-09-2013, 07:35 AM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
Hey heavy,
I finally got around to weighing mine. Here are the details:
Steve Theodore - 3320 (- 175 lbs)
-removed upper back seats,
-removed rear bumper,
-removed rear wing hydraulics,
-rear wiper/wiper motor delete,
-custom stock (de-catted) exhaust,
-removed spare tire and rest of junk from trunk,
-Fikse Profil 13 wheels,
-half tank of gas
Thanks!
ID:	230077   Click image for larger version
  #782
Old 04-22-2013, 11:46 AM
heavychevy's Avatar
Thanks Steve, Updated.
  #783
Old 07-01-2013, 06:21 AM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
Hi,
Here is what i ended with 3287 lbs / 1491 Kg - 1/2 tank
Battery: Stock
Spare Tire and Tools Removal
Wiper Delete
RWD Conversion
GT2 Seats
Clutch/Flywheel Items: cm3/stock
Exhaust Items: race headers and 3" x exhaust from 911tuning
Subwoofer Removal
removal of wing motor mechanism
Wheels Factory 996 Turbo Hollows
8x18" with 245/40/18 runflats very heavy
11x18" with 305/35/18 MT et streets 2, even heavier
removed rear seats,
with floor mats
rear seatbelts delete
Rear wing motors
KW v3 suspension
Additions:
1/2 tank
heavier turbos, bigger ICs, nasty fuel system, meth system
Fire extinguisher
Old 07-02-2013, 10:40 PM
Vendetta's Avatar
Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !Vendetta Is a GOD !
Impressive work, Fadi! When do we get video?
-V
  #785
Old 07-03-2013, 01:15 AM
layinback's Avatar
layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !layinback Is a GOD !
Originally Posted by Fadi
Hi,
Battery: Stock
Wiper Delete
RWD Conversion
GT2 Seats
Subwoofer Removal
removed rear seats,
with floor mats
Rear wing motors
KW v3 suspension
Additions:
1/2 tank
Fire extinguisher
You gotta beast Fadi. I know all the work you put into this car.
Ditch those factory twist. I know they're hollows but they're heavy.
Factory battery is 50 lbs and odyssey is 24. Rims + battery = 60 lbs
savings!
  #786
Old 07-08-2013, 02:17 AM
Fadi's Avatar
Thank you guys for the kind words, i hope soon to be able to raise the boost and do some proper testing. I really consider some OZs
  #787
Old 07-10-2013, 10:34 AM
b4stiTTS's Avatar
b4stiTTS has a spectacular aura aboutb4stiTTS has a spectacular aura about
Today I installed my new Michelin Pilot Super Sport Tyres, here are the weights:
Front 245/35 R19, 10,5 kg or 23,14 lbs
Rear 305/30 R19, 13,5 kg or 29,76 lbs
  #788
Old 07-13-2013, 05:50 AM
b4stiTTS's Avatar
Maybe no weight reduction but interesting to know how much weight you add to rotating masses when adding wheel spacers.
All the spacers are from FVD Brombacher and measured as a set of two
7 mm wheel spacers + longer bolts, 1,71 kg or 3,76 lb
15 mm wheel spacers + longer bolts 2,59 kg or 5,70 lb
23 mm wheel spacers + longer bolts 3,45 kg or 7,60 lb
OEM bolts 1 kg or 2,20 lb
  #789
Old 08-20-2013, 11:51 PM
pwdrhound's Avatar
Weighed in at the track this past weekend on freshly calibrated scales:
3263lbs with 1/4 tank of fuel...
  #790
Old 08-22-2013, 01:30 PM
b4stiTTS's Avatar
Front 245/35 R19, 10,5 kg or 23,14 lbs each
Rear 305/30 R19, 13,5 kg or 29,76 lbs each
Front was rubbing due the new Bilstein PSS10, now I have Michelin PSS
Front 235/35 R19, 10,2 kg or 22,47 lbs each
Weight of my car 3285 lbs with 1/8 of fuel and no Driver
  #791
Old 08-27-2013, 04:10 PM
pwdrhound's Avatar
Sway bar weight:
H&R rear adjustable (solid): 9lb, 14oz.
GT3 rear adjustable (hollow): 3lb, 8oz.
GT3 front adjustable (hollow): 7lb, 2oz.
996T front non-adjustable (solid): 5lb, 13oz.
  #792
Old 08-29-2013, 12:38 PM
b4stiTTS's Avatar
I changed the spacers in the back to 11 mm on each side, also from FVD
11 mm wheel spacers + longer bolts 1,98 kg or 4,36 lb
  #793
Old 11-25-2013, 02:27 PM
johnny.dangerous's Avatar
johnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud ofjohnny.dangerous has much to be proud of
Hi from the UK guys, ive lost a bit of weight but put some dynamat back in to keep it quiet !!! I doubt ive put the equivalent of the rear seat/belt delete back in, Im waiting for some kevlar seats to replace the full power ones, I have in place Ti exhaust (under 20lbs) Ti decats (very light) rear seat delete, rear belt delete, rear wiper delete, no spare or tools, 5lbs LiPro battery, I will weigh her as soon as she is back together.
  #794
Old 11-25-2013, 03:00 PM
layinback's Avatar
I hear you bro! I pulled all factory carpet and sound deadening and installed
Ozite carpet and paperboard molding. Ozite looks as good or better than
rs carpet , it's durable and it weighs 18 ounces per square yard. But the cabin
sounds like a nuclear holocaust.
  #795
Old 11-25-2013, 03:13 PM
Its always a road car at the end of the day, id rather keep 50 lbs of luxury and turn the boost up a bit !!!!!! Just trying to order some bigger turbos in Tial housings !!!
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
Quick Reply: Official Turbo Weight Loss Thread/ Lightest Turbo List
