Diverter valves: Maintenance or Performance ??
The most obvious symptom is loss of boost. What happens is the rubber diaphram blows apart (disintegrates) and the rubber can go into the turbos. The problem is that you might not know they blew and that can lead to pre-mature turbo damage. Consensus is that when you are boosting over .7 bar, you should just change them to prevent this damage.
from EVOMS. It called searching.
in between shifts when the valve is suppose to open to re-circulate the built up boost pressure, if it is defective and cannot open, the built up manifold pressure will "stall" the compressor of the turbocharger causing it to rapidly slow down which can cause turbocharger failure. This "stalling" of the turbocharger will also increase turbo lag in between shifts and reduce power.
Originally Posted by wross996TT
The Forge is the one I and some tuners would recommend!
Dave, Congrats again on your Turbo. But you may not "need" these valves with your mod list. At least consider a V-Flow/BMC and GIAC (both from the EvoMS family) to accompany them.
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
