Dip in HP/TQ on my Dyno (X50 w/ GIAC/Evo)
The car is an X50. With a Europipe only on a pretty cold day, it dyno'd 433WHP and 455TQ. I have since flashed the car and added the Evo wastegate kit. Today, I redyno'd. It was warmer, but the results are still not what I expected. The best run was 459WHP and 510TQ. The torque gain is inline with expectations, but the WHP has only gone up by 26. There is a dip in HP/TQ from about 4200-4600 RPM now.
My concern is that the Evo wastegate actuators are not tuned correctly. They were not pre-set with a pressure tester rig before installation, but were supposedly tuned after installation and driving. If they are set wrong and the car is making too much boost, could that be the culprit for the power dip? I have driven the car flashed for a while, but only had the wastegate kit on for a week. From what I've seen by watching the boost guage, there doesn't appear to be any wild spikes.
Any ideas? Yank the evo actuators and test them with a pressure tester? Put the stock ones back in?
X50 + Europipe (No flash or wastegate mods)
X50 + Europipe + Flash + Evo Wastegate Kit
Originally Posted by nash
The guys who did the wastegate install had not done one before, but they are an Evo dealer.
That was my fear, too. Did he calibrate them with a pressure tester before installation, if you remember? It's a no-brainer to do the actual installation, it's the calibration that's the trick
I actually think ur throttle body is shutting down... maybe ur hitting 1.3 bars of boost and the car is pulling timing/closing the TB...
markski
2001 996TT 3.6L and stock ECU
markski
markski
Originally Posted by LUIS95993
Wouldn't the TB shutting down throw some codes Mark?
take the car out and run it in 4th from 4K to 6500 rpms and see what happens... the car might even go into limp mode if u stay in it long enough.
NOTE: if it didnt happen b4 the WG switch then the problem must be the preset of the new WGs...
Is there some measurement (in mm) from the rod to the tip of the nut that is "correct"? Man, that is a dirty sounding question.
I distinctly remember seeing 1.3 flash up on the boost gauge during the one pull that I did watch (4th gear). So perhaps you are correct, Markski. I'll take it for a drive later tonight - what should I be looking for from 4k to 6.5k?
Unfortunately I don't have a dyno with just Flash and no wastegates. But the only changes to the car since it was dyno'd last are the flash, the wastegates and a few months of driving. So the most likely suspect are the wastegates.
And yeah, I'm thinking they might have them cranked too high (too much boost). If the TB shuts down when boost is 1.3 or higher, then this definitely could be the problem. I have seen 1.3 this weekend when driving around, and did see it on the dyno.
I just changed mine out (wastgates) and they should be set with a pressure tester. very easy to do. low pressure regulator and a good low pressure guage 0-15 or 0-20 psi they must be done on the turbos. at 12 psi they should begun to crack open adjust them evenly.
Nash,
when u pull it in 4th stay in it full throttle and see if it stays at 1.3 bars.... if it does then thats probably ur problem. Giac flash does not allow u to go past 1.3 bars on ur kit. they turn it off in the GT 640 and up kits.
u may need a half a turn down on ur rod or so.
Once set up correctly it works good.
