FVD's Air Intake Plenum
i have all the parts (Mods) fitted except this part that is left, i'm having second thoughts about it since i have allready invested so much money in Mods, how important is this part, does it make a lot of difference performance wise when installed, is it worth it?
In FVD website they claim that this part add 25HP. |
It is all about flow...get it done.
What turbo's do you have?
isnt there a greater chance of blowing the maf with these?
It depends on your other mods and HP goal. The OEM piping between the airbox and the turbos is probably adequate for K16s with upgraded programming and an exhaust making 500 hp. On the other hand, if you are using after-market turbos and seeking 600+ hp, the OEM piping may be restrictive and upgraded piping is probably warranted.
BTW, there are several options for upgraded piping between the airbox and the turbos, including FVD, Gemballa, EVOMS, Speed Gallery, S-Car-Go, Prototmotive, and likely UMW as well. Craig |
You will definately increaee airflow with the FVD Intake. |
To add onto the post by Craig, could any users or the vendors of the above plenum options (FVD, Gemballa, EVOMS, S-Car-Go, Speed Gallery, Promotive, and UMW) post:
- pics - their results (HP and/or ET improvement) - some general comments on the performance and installation I think this could be really helpful as this is one of the few performance parts that gets any attention, and is surely one of the most restrictive in stock form. Thanks in advance! |
i have FVD's K24/K26 Racing turbo's, fuel pressure regulator, diverter valves Moded ECU, BMC air filter, Racing clutch/flywheel, exhaust system with headers, GT2 intercoolers
- pics - their results (HP and/or ET improvement) - some general comments on the performance and installation I do not have any photos or data for the units sold by EVOMS, IA, UMW, Protomotive or S-Car-Go. These are photos of the Gemballa unit: http://gallery.rennlist.com/albums/C...nsaugrohre.jpg http://gallery.rennlist.com/albums/C...nsaugrohre.jpg Craig |
What's the going rate for these?
Craig |
Craig |
markski |
Originally Posted by Zippy
Definately. When I first had the GT640 kit, I was OK with the MAF. I then installed the FVD Intake and the EVO VFlow at the same time and 2 things happened.
So you're saying that by increasing the diameter and efficiency of the pipe directly behind the MAF (sucking through from the turbos) can't increase the flow going through the MAF? :confused: Sorry, I respect your opinions, but you're dead wrong on this one.
| All times are GMT -6. The time now is 03:34 AM. |
