Oil Change help guys.
Alright I have decided to do my own oil change and want to know how quart of oil does turbo take and what oil filter I should buy for it. Always had the shop do it for and decided to switch things up a bit.
These are the parts you will need:
996 107 225 52- oil filter O ring
999 707 465 40- small O ring
900 123 010 20- copper sealing ring for oil tank
900 123 118 30- aluminum sealling ring for engine
996 106 665 55- 9 quarts of Mobil 1 0W- 40
see link below for full write up:
http://www.renntech.org/forums/index...e+instructions
Regards
Sameer
Regards
Sameer
Mistry is right about the seals and rings. But, you forgot the two seal rings for when you drain the turbos. Each turbo has its own drain plug. Also, I would only use the Porsche factory filter.
hacellular
Aug 31, 2015 08:34 AM
