Ported Exhausted Manifold!
Old Mar 29, 2004 | 03:57 PM
Weazel's Avatar
Weazel is infamous around these parts
Exclamation Ported Exhausted Manifold!
Just wanted to show pictures of a ported 996 exhaust manifold that we did here in house. The welds were also redone on the outer flange. Hoping to get some gains over previous numbers. We were also doing some testing on intakes and exhausts. I'll update with results in future posts.
Old Mar 29, 2004 | 04:09 PM
luting_chen's Avatar
luting_chen is infamous around these parts
wahahaha... is that my header?
why not ceramic coat the exterior too... hehehehehe
Old Mar 29, 2004 | 04:15 PM
btw... SP is da best ^_______________^
Old Mar 29, 2004 | 04:22 PM
Weazel's Avatar
Yes, it's going to be coated as well....
Old Mar 29, 2004 | 05:12 PM
hehe... what about port my evo exhaust and coat it as well next time ^_________________^... i don't think there is anyone that port and coat the evo exhaust yet...
and please do keep us updated on the test results...
Old Mar 29, 2004 | 05:18 PM
pieball's Avatar
pieball is infamous around these parts
That's all fine and dandy, but what's up with all the imperfections in the tubes! I know you can't get them out without possibly popping through, but what the hell did they look like before you got to them?!?!
Old Mar 29, 2004 | 05:39 PM
Weazel's Avatar
i'm going to try and get you before pictures...
Old Mar 29, 2004 | 05:51 PM
james's Avatar
Carolina Speed
james is infamous around these parts
just remember, the tiniest hole, and BOOM you just lost all your power and then sound like a schoolbus. When switching from stock, go with what has been tested. Even GHL has had problems with one of their designs. Good idea on the overweld. I would like to know the flow diff between stock and ported stock. Then ceramic coat over the ported and settle once and for all what means anything.
Old Mar 29, 2004 | 05:55 PM
pieball's Avatar
It'll hurt too much to see the before shots! I don't remember mine looking like that but then again they were all carboned up...
Old Mar 29, 2004 | 06:07 PM
TURBOALEX's Avatar
TURBOALEX is infamous around these parts
its got welding in the ea runners,its looks so bad did not take any pics sorry alex
Old Mar 29, 2004 | 07:11 PM
cjv's Avatar
cjv
Moderator
I can tell you by what I see, you did not do it correctly. By removing certain metal on the top lip like you did you induce what they call sound harmonics (sound waves) back into the valve train. Having a certain ledge at this point helps power.
Old Mar 29, 2004 | 08:15 PM
Weazel's Avatar
Well, cjv, we are currently testing the porting on the manifold, as oppose to the rough welds when it comes stock. We deal with high horsepower vehicles on the daily. If this proves to make some power, we're just looking to show 996 owners easy ways to gain power at minimum costs. If we're wrong, then we learned something new as well as if it did gain power. Check us out, we've been around and now are currently testing 996's.
www.sp-power.com
(Go to showcase)
Old Mar 29, 2004 | 08:24 PM
sharkster's Avatar
I have some pix somewhere of the ones that Kevin did for the shoot out. He had to spend an immense amount of time (I'll let him fill you in) and man hours so the process, whilst cheap in one sense isn't really because it's very labor intensive to get it just right aka no imperfections in the tube and collector.
Old Mar 29, 2004 | 08:33 PM
cjv's Avatar
cjv
Moderator
What I am refering to is known by people who port heads. If you have a matching port the waves go out the heads and down the exhaust. The waves reverberate back and will go back up throught the valves and combustion chamber. By having a slight ledge/lid on the upper side of the head, the sound waves hit the ledge and deflect back out the header. The two sides and bottom can match. A Graham Bell explains this much better in his book.
I am not sure what you would see between stock and match port like you are doing. However, if you did one like I explained and a match port, you would see what I am trying to explain to you.
Old Mar 29, 2004 | 08:35 PM
StephenTi's Avatar
StephenTi is infamous around these parts
I too am glad to see one of the top import tuners in the U.S. start to R&D our cars. SP Engineering builds amazing cars. They had a hand in my ex Supra, and their products and workmanship is top notch. Looking forward to what you guys will do next.
Stephen
'01 Turbo Ti Upsolute
455rwhp, 505 rwtq
1stephen1.com
