4.90 second 60-130 (4.23 100-200 kph) with 2 shifts
Old May 21, 2007 | 10:13 PM
  #76
MrBlonde's Avatar
Awaiting Email Confirmation
MrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to allMrBlonde is a name known to all
With nitrous on board I'd be looking at something larger than GT35R .. still within the Garrett ball bearing fold. Perhaps a pair of TO4Zs .. or the GT40R .. or T51R? I'd steer way from GT40R .. not enough of a difference with GT35R spec.
If GT42Rs work then obviously they would be the turbo of choice. There would be no stopping a pair of GT42Rs once they come on full boost with a stroked engine.
This is me talking out of my **** just based on the recent real world findings, the pro tuners (and big dogs) here all know much more than I do about it.
Old May 21, 2007 | 10:19 PM
  #77
taizen's Avatar
taizen is infamous around these parts
Congrats. Promotive just keeps building monsters.
Old May 22, 2007 | 02:50 AM
  #78
Divexxtreme's Avatar
Thanks again, guys.
Just a FYI...I'm on my way out of town this morning for some military training until Friday. Won't have internet or phone access until I get back. Have a good one.
Old May 22, 2007 | 07:19 AM
  #79
buddyg's Avatar
I am curious if you built a 4.0 liter motor could you use GT42's and reduce the lag versus using a stock 3.6? Would it perform more like a GT30 on a 3.6 motor as far as lag/spool time?
Old May 22, 2007 | 08:54 AM
  #80
MrBlonde's Avatar
Despite what the engineers tell you there is exactly one way to find out.
Old May 22, 2007 | 09:05 AM
  #81
cjv's Avatar
cjv
Moderator
Buddy,
You still have some lag with the 42's. We arrived at the 4L with 102 mm pistons which brought it to a 3.8L and a 80 mm crank which brought it to a 4.0L.
The bore resulted in a little more power and a little more torque. The .2L stroke resulted in alot more torque in the lower/mid rpm's. I believe the 42's on a 3.6 would have alot of lag ........ really unusable. The 35's on a 4.0L respond better that 30's on a 3.6.
Old May 22, 2007 | 09:52 AM
  #82
OhioGT2's Avatar
OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !
Scott, awesome times! Stop teasing me to build my motor!!!
Old May 22, 2007 | 09:55 AM
  #83
dgussin1's Avatar
dgussin1 is infamous around these parts
a single gt42r (smallest available) is enough to support 850bhp, I don't see the need for twins from a 4.0L engine unless being run at well over 30psi to see it's performance benefits and even then, it will still be a dog down low.
Old May 22, 2007 | 10:33 PM
  #84
Zippy's Avatar
Holy ****e Scott your car is smokn'!!!!
It's very exciting to see the "next big thing" come out of Protomotive.
Todd & Cynthia are amazing.
I nkew you were a very skilled 1/4 mile track animal, but for the life of me I can't figure out how you can accelerate with the clutch depressed? How do you do that?
Congrats again to you, Todd & Cynthia. I'm soo jelous!
Mike
Old May 22, 2007 | 11:50 PM
  #85
S4corrado996TT's Avatar
S4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really niceS4corrado996TT is just really nice
Wow faster and faster! Congrt Drivextreme! By the way! did you run at stock weight?
Old May 23, 2007 | 12:23 AM
  #86
MrBlonde's Avatar
Turbo selection: science and magic at the same time!
You always start with how much power you want to make. That determines what turbo choices you have. Then you use the various compressor and turbine options to configure the turbo to best suit your application.
However despite all the misinformation and plain ignorance, there are some plain facts available to Joe Public:
+ GT28R: Compressor inducer is 52.7mm. Rated at 480 bhp
+ GT30R: Compressor inducer is 57.0mm. Rated at 600 bhp
+ GT35R: Compressor inducer is 61.4mm. Rated at 700 bhp
+ TO4Z: Compressor inducer is 66.7mm. Rated at 800 bhp
+ GT40R: Compressor inducer is 67.8mm. Rated at 800 bhp
+ GT42R: Compressor inducer is 70.3mm. Rated at 850 bhp
+ GT42R: Compressor inducer is 74.3mm. Rated at 1000 bhp
+ T51R: Compressor inducer is 76.5mm. Rated at 1,000 bhp
+ GT42R: Compressor inducer is 80.8 Rated at 1,100 bhp
Old May 23, 2007 | 07:39 AM
  #87
buddyg's Avatar
So if you built a 4.0 liter motor would GT35's be the best way to go? According to the chart above a pair of those would support up to 1400 hp?
Old May 23, 2007 | 08:33 AM
  #88
TRK's Avatar
TRK
TRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to beholdTRK is a splendid one to behold
Optimistic turbo sizing
Buddy,
One thing Garrett's not telling you in those catalogs, is those are MAXXED out numbers on those turbos at CRAZY boost pressures to get there. We're making a lot of power with much less boost, and tend to be compressor limited at the lower pressures. For instance, a GT3071R has a 50lb compressor, Garrett rates it up to 460hp, but we're only seeing 9.25hp/lb/min, so I'd rate it at 425.5hp... However, it only produces that flow at 2.2 bar! It's almost 20% less at 1.2-1.4 bar boost where we'd be comfortable running it. And at those levels, it's out on the 55% efficiency island, so you're producing a tremendous amount of heat. And that's in a large Garrett housing, not a recontoured k24 compressor housing... Even in the smaller T04B style housing, they just ran into a wall on Jamies at 630whp or about 741crank, which is saying they're only flowing about 40lbs in that configuration.
The GT3076r's started converging at high rpm at 830rwhp on Scott's or 976crank. They have a 52lb compressor, and at 9.25hp/lb/min that's 481hp each, or 962hp for the pair... So we were right on with those, but those had the huge 4.0" inlets and landed in some nice efficiency islands.
On the GT35R's, they say 600hp, but with a 62lb compressor, at 9.25hp/lb/min that's 573hp/turbo or 1147hp at the crank, for about 974whp on a dynapack, or 940whp or so on a dynojet... Unless you're willing to run huge boost pressures, the 35r's seem to like 30+psi of boost and get really happy there. But we're not playing with Mitsubishi's and Honda's that you can get a replacement block for $800.00 ;p
So, 42r's, I believe would be pretty excessive, unless you were only after dyno numbers. They'd be pretty bad on lag, probably not coming on till 6000rpm's or so. You may improve that with 4.0 or 4.2L and nitrous down to 4000 rpm's or so which would be nice. But that would really only be for drag racing. Otherwise, you'd forever be refilling your bottle ;p Or tolerate monsterous lag. vralexander put a set on his supra, but they run to 10,000 rpm's, so 6000 rpm onset is ok... and he had some supercharger and nitrous to get them going...
Sorry, enough rambling.
Old May 23, 2007 | 10:49 AM
  #89
WOODTSTER's Avatar
Excellent Education once again!! Who else has ever given us such good
info. Funny thing is I just had Todd explain all of this over the phone to
me which helped me confirm the K24/18Gs will be perfecto for MY goals @
40lbs each.
I believe in addition to a new King, we may have a ne "Doctor" in the house...
MK
Old May 23, 2007 | 06:22 PM
  #90
MrBlonde's Avatar
Originally Posted by TRK
Buddy,
Todd,
And there are many choices of Garrett ball bearing turbos in between the GT35R variants and the GT42R variants ... any comment on those?
The question above was what can you do with a 4.0 litre engine using nitrous to spool. Agreed that a drag racing only proposition, however for the sake of the exerise what are your thoughts on turbo selection?
