5 minutes to adjust PSS9s??
I have read numerous times that it only takes 5 minutes to adjust PSS9s. I always assumed that PSS9s would be like the GC coilovers I had on my BMW ... adjustment ***** up top ... which make it a piece of cake to adjust them. But now that I just received my PSS9s I see that the adjustment ***** are actually on the bottom, so my question is, how the heck do you easily adjust them in "5 minutes" like I see thrown around so much? I can't just slide under the car ... it takes more than 5 minutes just to get the car on jackstands! Anyway, does anyone have any tricks or whatever on the best/easiest way to adjust these things once they are on the car??
The rears are under the carpet close to where the ECU is and don't take long (unless you have a roll bar lol). The fronts, technically some people claim to be able to dial in their settings by "feel" but since the detense is so ****e, I can never hear anything and hence I do jack up the car to do it.
Sharkster is correct. And it really does take less than 5 minutes to jack the car up high and place one jackstand underneath (opposite side) and adjust the settings in the front. One piece of advice is to place a tiny amount of car wax inside the light blue cover cap so that it slides on and off easy. Before I did this, those caps were a ***** to get off b/c the harder you squeeze the tighter they grip. Now the backs I wish were on the bottom b/c I have to remove the bose subw and peel up the carpet squares. That takes me ten minutes. Total time: < 15 minutes.
