Upgraded Turbo HP. What should I be putting down?
Old Jul 1, 2007 | 02:53 PM
nigelquest's Avatar
nigelquest is infamous around these parts
Can you guys please give me a rough idea of the HP at the crank and wheels for an 996tt manual with the following mods -
K24 turbos
Orton ECU tuning (1.0-1.1 bar)
AWE exhaust
BMC Sport Air Filter
converted to rear wheel drive (less drive train loss)
Also, any recommendations on what else to compliment this setup are appreciated. Thanks!
Old Jul 1, 2007 | 03:05 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
I'd guess around 500 whp. I'd also make sure to do dv's.
Old Jul 1, 2007 | 03:45 PM
nigelquest's Avatar
Any suggestion on the DVs? Somewhat new to the turbo, but the DVs are the blow off valves right?
Neil@Orton's Avatar
Neil@Orton is infamous around these parts
Around 550 FWHP.I think this is the car at Lambo store.Is this seal grey?
If you need any info drop me a PM.
Neil
Old Jul 1, 2007 | 04:32 PM
Dr_jitsu's Avatar
If you do the DV's you should come close to 480 at the wheels. 500 would take a new intake and maybe headers.
Old Jul 1, 2007 | 04:55 PM
OhioGT2's Avatar
OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !OhioGT2 Is a GOD !
Sean, how much additional HP do you estimate your DV's give you?
Old Jul 1, 2007 | 05:08 PM
wross996TT's Avatar
Dvs do not give any horse power...the reason you replace them is because the stock ones will eventually go , especially with the higher hp (my guess is this has already been done?). How do you intend to drive the car? This will effect additional mods (I'm thinking LWFW for example)...as far as headers, just P&P the stock ones...intake...that is another question...I went for the sportec as the V-flow and I did not get along. You might also do the intake plenum...FVD for example. and also wastegate kit!
Old Jul 1, 2007 | 05:52 PM
OhioGT2's Avatar
Correct. But you took the fun out of waiting for Sean's answer.....
Old Jul 1, 2007 | 06:32 PM
banditlex's Avatar
banditlex is infamous around these parts
hyperboost dvs should work fine with that setup. They aren't that expensive.
Old Jul 1, 2007 | 07:19 PM
Divexxtreme's Avatar
Jamie, just like Sean...you need to let this go. 3-day ban.
Old Jul 1, 2007 | 07:38 PM
Fanman's Avatar
Fanman is infamous around these parts
I think there are a few 996 TT's running very similar setups on this board. In general I think the K24's can get up to 1.2 BAR which I think would be good for around 510+ rwhp
Old Jul 1, 2007 | 07:59 PM
CarNerd's Avatar
DV's are diverter valves not blow off valves. I went with EVO's DV's. +1 on the wastegate kit too.
Old Jul 1, 2007 | 08:00 PM
CarNerd's Avatar
What just happened?
Old Jul 1, 2007 | 08:03 PM
What just happened?
Long story. Back to the thread.
Old Jul 1, 2007 | 09:06 PM
MidnighTT's Avatar
MidnighTT is infamous around these parts
If you decide to grab a pair, I have two Baileys DVs available. $150 shipped for both of them, which is about 1/2 the price of new. PM me if interested.
Jeff
