hitachi maf GT700s - anyone w/ LWFW?
Old Aug 28, 2007 | 01:24 AM
carendt242's Avatar
carendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the roughcarendt242 is a jewel in the rough
my car has a small stalling problem when driving around in city traffic semi-aggressively. it happens in spurts, repeats itself 3-4 times, and then it's done for the night.
does anyone else have this combo? if so, do you have any stalling problems?
(this is on 100 race file - never use the 91 file.)
- chuck
Old Aug 28, 2007 | 02:16 AM
I would get it when slowing down almost to a dead stop after I put the car in neutral.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 28, 2007 | 02:30 AM
NelsonF's Avatar
NelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to beholdNelsonF is a splendid one to behold
Lwfw
I see this on occasion with my GT700 GT2 w/ LWFW. I also almost exclusively on the race file with 104 unleaded. Typically, it happens when coming to a stop from 3rd gear or beyond. The LWFW allows the rev's to drop too quickly and it will stall sometimes if I don't take it out of the lower gear fast enough. If I downshift prior to all stops (instead of just going from 3rd or 4th to neutral) or feather the throttle while
doing stop and go's, I can prevent it from happening. Seems like a LWFW issue allowing revs to drop too much although I did not have this issue with my GT700 TT. BTW, I don't have the Hitachi MAF. Hope this helps.
Old Aug 28, 2007 | 03:38 AM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Happens to me once in a while. I am going to see if Todd K. can bump up the idle speed or advance the timing a bit to keep it from dropping down.
Old Aug 28, 2007 | 08:40 AM
PorschePhd's Avatar
It is normal with the L/W setup to stall every now and then. The inertia is not there and when you throttle off the L/W drops so fast that the computer can not compensate faster than the flywheel slowing down and it dies. This was a serious issue on the 993TTs to the point we had to add some weight in order to keep the car steady.
Old Aug 28, 2007 | 08:42 AM
PorschePhd's Avatar
Old Aug 28, 2007 | 08:54 AM
PorschePhd's Avatar
Old Aug 28, 2007 | 09:04 AM
wross996TT's Avatar
OK we heard you...something wrong with the site right now...anyway I had the problem before a little ecu tune and now all is OK.
Old Aug 28, 2007 | 10:15 AM
NelsonF's Avatar
Lwfw
It appears that the previous dual mass flywheel would have addressed this situation better. Wonder if GIAC vendors have an ECU upgrade fix?
Old Aug 28, 2007 | 11:48 AM
carendt242's Avatar
the reason i asked specifically re: the Hitachi MAF programming was b/c i had no issues w/ the old GT700 programs.
w/ the first 104 file, i had major issues w/ stalling - every stoplight. w/ the newer 100 file, i just get them from time to time (hot or coool outside.) but when it happens once, it will be happen 2-4x more within the next few minutes. then everything is good again.
just wondering if i was the only one experiencing this w/ the hitachi gt700 programs w/ LWFW or not.
- chuck
Old Aug 28, 2007 | 12:24 PM
andyk79's Avatar
andyk79 is infamous around these parts
Yeah I have the same issue as well. Every once in a while the car just dies in the middle of the road at a traffic light and its quite embarrassing. Everyone looks at you as if you just killed the clutch.
Old Aug 28, 2007 | 01:13 PM
PorschePhd's Avatar
Sorry about that. I cleaned it up. I have no idea what the hell happened. Site is a little whacked today. I even had issues moderating those post.
Bobbyfali
Jul 31, 2017 01:28 AM
BLKMGK
May 31, 2016 04:32 AM
WheelsupZR1
Oct 20, 2015 08:36 PM
panas001
Sep 27, 2015 02:51 PM
