Sway Bar Help!
Old Sep 19, 2007 | 09:41 PM
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
Exclamation Sway Bar Help!
My car is currently lowered to GT2 specs via Motons and i recently install H&R sways both front and rear with TRG drop links up front. The problem is, my front sway is hitting my control arms when going over small bumps and pot holes. I jacked the car up to take a look and the sway is sitting above the control arms a good 3/4" to an 1". I shortened the drop links as much as i could but am still having this problem. Any suggestions? Please advise! Thanks!!
Old Sep 20, 2007 | 07:27 AM
WOODTSTER's Avatar
Call Sharkey
Old Sep 23, 2007 | 12:04 AM
CarNerd's Avatar
So no ideas? Am i the only one who has dropped a Turbo down to GT2 height and run into a problem like this?
Old Sep 23, 2007 | 05:34 AM
live2shift's Avatar
live2shift is infamous around these parts
I had the same problem with the H&R's and I seemed to be the only one at the time. I was hitting in the rear. See my post. I called H&R and didn't get any resolve. The adjustable drop links solved the problem for me. Has you car ever been on a trailer, sometimes people tie the car down by the aluminum control arms and bend them.
https://www.6speedonline.com/forums/...ad.php?t=70600
Old Sep 23, 2007 | 06:32 AM
buddyg's Avatar
My car is slammed to the ground with front and rear sways and I have never had this problem?
Old Sep 23, 2007 | 06:36 AM
WOODTSTER's Avatar
Did you call Sharkey yet?
Every car is different, some hit, some break the drop links, some have no problems.
Sharkey's guys do alot of these suspensions, call him.
I have also had problems, but I have a JIC, I am not set as low and I have different
drop links than you so I cannot tell you what would help on your car.
Good luck,
MK
Old Sep 23, 2007 | 10:12 AM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
mine hits on rear .. took it off have heard so many stories on broken drop links,, more research i guess...
Old Sep 23, 2007 | 10:13 AM
woodster ya i know see alex .... will do so wed next...
Old Sep 23, 2007 | 11:23 AM
CarNerd's Avatar
Yah i actually talked with Alex yesterday but he doesnt have anything open until the end of the week.
Old Sep 23, 2007 | 11:25 AM
CarNerd's Avatar
Hm... Buddy what links are you using?
Old Sep 23, 2007 | 12:36 PM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
Ned, It must be your Sway, I'm running Motons and TRG Links with Stock Front Bar and it's ok, get the H&R of the front and leave it on the back. The Stock unit on the front is more than adequate.
Old Sep 23, 2007 | 02:01 PM
CarNerd's Avatar
Are you at GT2 ride height?
Old Sep 23, 2007 | 02:32 PM
Off the top of my head, rear (wheel arch height) is exactly 25" and front is just below this
Old Sep 23, 2007 | 02:35 PM
I did also measure at the correct points underneath car, but can't for the life remember, think front was 108
Old Sep 23, 2007 | 02:41 PM
BTW Ned, the car is on rails!
