996 Turbo Vendor Classifieds
600 - 700HP Turbo Kits on SPECIAL
Old Sep 7, 2008 | 12:38 PM
vividracing's Avatar
We are moving to our new facility really soon and I have stock of products that we need to get moving out the door. This includes all the basic turbo kits and components we carry plus parts to complete a 800HP Turbo Kit. All items are instock, any questions, CALL ME or PM ME. We have customers all over the world running our K16/16G, K24/18G, Garrett GT2860rs and GT3076 Turbo kits.
Specials are good till instock quantity is sold out or December 1, 2008.
You can view products here as well - http://www.vividracing.com/catalog/turbo-sc-turbos-kits-c-4266_4279.html?class_9=2335&my_type_id=8&my_value= 38&class_8=38
Agency Power K16/16G Turbo Upgrade Kit - 550-600 Crank Horsepower - $3300 Shipped
Not looking to break speed records, there is way to squeeze alittle more power from the K16's to pass their stock efficiency. The factory turbine wheel moves about 30lbs/min. With the 16G upgrade, you will see a gain of about 10lbs/min. Basically saying, the stock K16 turbos are good (based on turbo parts) for 550 crank horsepower. Of course depending on types of dyno's, boost settings, fuel tuning, etc, we would say at a 20% drivetrain loss for the AWD. This upgrade would increase the power output of your stock Porsche 996 Turbo K16's by (again based on turbo parts) about 60-80 crank horsepower.
Maintaining quick spool with an OEM fit and headache free upgrade, you will see a large increase in mid to top end horsepower. By running the same amount of boost you do now on a flashed K16 car (1.0-1.1bar), you will make more power since you are moving more volume of air. This upgrade DOES NOT require more fueling. It does require doing an ECU Flash. Softronic has been doing ECU tuning for more then 15 years. Having done 1000 of ECU flashes for customers with all types of turbo upgrades including the K16/16G for, Softronic has a file ready to get your car going fast. Softronic has been tuning the K16/16G on 993TT and 996TT for many years. With the turbo upgrade, you get a Softronic OBD Flash Cable which allows you to retain your stock map and do the ECU flash yourself. There is no need for inhouse tuning, chip soldering, or using a "Tuner". Softronic tunes using the factory knock and O2 sensor so basic bolt ons or octane changes do not require an new flash. The computer will adjust for these.
Agency Power K24/18G Turbo Upgrade Kit - 600-625 Crank Horsepower - $6000 Shipped
K24/18G Hybrid Turbos - Brand new Modified Turbos using the stock internal wastegates. These have quick spool, big midrange power, and are good up to almost 625 crank horsepower. Already have K24 turbos? Send in your turbos to be modified with the 18G exhaust side and reduce the price by $2500!
Softronic ECU Flash specific for your octane, environment, and the K24/18G turbo setup. You receive a client cable to do on the car flashing for easiest and convenient updating. Softronic gives you the best map the first time. No need for race files as the map will adjust to the different octane you put it in. With Softronic you get the ability to retain your stock map.
5 Bar Fuel Pressure Regulator to deliver the additional fueling needed for the increase in Horsepower.
Watch it rip on the dyno here - http://www.youtube.com/watch?v=pFCWn6cP25Q
Agency Power Garrett GT2860rs w/Tial 44mm Wastegates Turbo Upgrade Kit - 650-700 Crank Horsepower - $8500
Still the ONLY true Garrett bolt on turbo upgrade available for the Porsche 996TT, Agency Power has a complete kit that will punish the competition. This modular Garrett based turbo kit uses Garrett GT2860RS turbos, Tial 44mm external wastegates, high high high quality stainless steel headers with a true merged collector, billet aluminum oil tanks, oil lines, water lines, exhaust adapters so you can use your stock exhaust, 5bar FPR, and has a proven track record!
External wastegates provide up to 40ft/lbs more torque then a standard turbo with internal wastegates. You can hear the sound of them as they rip at open throttle. Watch the videos here -
http://www.youtube.com/watch?v=HIpqG97j9J0
http://www.youtube.com/watch?v=Sx9Qz4VgEEs
http://www.youtube.com/watch?v=QB01xc8rZwE
This kit like the others uses the Softronic ECU Flash Tuning which you load the file yourself via the OBDII port. We end you a flash cable which allows a very easy process to complete. Like all Softronic flashes, they are tuned off the factory knock and oxygen sensor to give you the best map and adjust to your octane and race gas as needed. At 1.3 bar this kit makes an aggressive 540awhp on a Mustang Dyno (40 less then a DynoJet!).
Want 800HP? Upgrade to GT3076 Turbos, RC 60lb Injectors, Ford MAF with Softronic Programming, New Rods, Pistons, Head Gasket, Bosch Fuel Pump. Just Email Me for details - dan@vividracing.com
The Do It Yourself Turbo Projects
Agency Power Garrett Turbo Hard Parts Kit - $4000
Kit includes the headers, dump tubes, oil lines, water lines, fittings, Oil Tanks, Exhaust adapters, hardware to run Garrett GT ball bearing turbos.
http://www.vividracing.com/catalog/agency-power-afi-garrett-gt-turbo-kit-components-porsche-996tt-0105-p-45759.html
Porsche OEM K24 Turbos BRAND NEW - CALL!!!.
Brand new original equipment Porsche K24 Turbochargers from the X50 or GT2. Bolt them on, do your own mod upgrades and gain more power. We have these turbos INSTOCK.
http://www.vividracing.com/catalog/porsche-oem-k24-turbos-porsche-996tt-x50-gt2-p-17221.html
Other Parts on Special For your Big Turbo Build
Old Oct 23, 2008 | 06:10 PM
In light of some recent postings, we are giving away a Agency Power Garrett GT2860rs kit at COST to show the quality of these components and how much power they put down. If you want Vivid Racing to install the kit, simply bring us the car and we will do the labor at 30% off. Drop off on Monday, pick up on Friday!
Cost of the Agency Power 650 Kit - $8500 BRAND NEW. Includes: Turbos, Headers, Wastegates, Oil Cans, Water Lines, Oil Lines, Fittings, 5bar FPR, Greddy Profec B, Softronic ECU Flash, Softronic Flash Cable.
This promo is going on till December 1, 2008. Check the above post for special price revisions!!!
Old Oct 28, 2008 | 03:26 PM
Bumping our thread, we are offering until November 15th....
Get the K24/18G Turbo Kit with 5bar FPR, 1.0bar Actuators, Softronic ECU Flash with FREE Durametric Cable (Diagnostic and Data Logging) and Get a FREE set of Agency Power Silicone Boost Hoses and Silicone FHose in your color Choice for $5995 SHIPPED. That is a $800 value for FREE.
There is no need to get an external boost controller as with the 1.0bar actuators the stock boost solenoid controls the internal wastegates and holds 1.3bar no problem. With our K24/18G kit, you can be assured you get the longest running ECU Tuning program by Softronic. With over 30 years of experience, Softronic has tuned and built more Porsche race engines then its competitors.
When you buy any turbo kit from Vivid Racing and use the Softronic ECU Tune, if you are not happy with it, reflash back to stock and we will credit you for the flash. That is how confident we are in the product.
This offer expires November 15,2008. Use any of our online communication tools below or call 1-480-966-3040 x222 for questions.
Old Oct 30, 2008 | 11:06 AM
Thank you for the order Mishari!
Old Oct 31, 2008 | 07:53 PM
rdf16's Avatar
rdf16 is infamous around these partsrdf16 is infamous around these parts
There is no need to get an external boost controller as with the 1.0bar actuators the stock boost solenoid controls the internal wastegates and holds 1.3bar no problem. With our K24/18G kit, you can be assured you get the longest running ECU Tuning program by Softronic. Softronic and Protomotive have worked together for years on ECU tuning. With over 30 years of experience, Softronic has tuned and built more Porsche race engines then its competitors.
I assume if I order this kit I am going to need a clutch. Options?
RD
05 Turbo S cab
Old Oct 31, 2008 | 10:41 PM
That is correct sir. We are doing the Clutch Masters Stage 3 full disk for $1500. You can see it here - http://www.vividracing.com/catalog/c...5-p-49671.html
If you want one, let me know!
Old Nov 4, 2008 | 05:06 PM
RickEager's Avatar
RickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond reputeRickEager has a reputation beyond repute
Is this kit safe for a tiptronic?
Old Nov 4, 2008 | 05:10 PM
RickEager's Avatar
Old Nov 4, 2008 | 06:56 PM
Of course it is safe for the Tip The tip produces great power and stays in boost. I highly recommend this turbo upgrade to a K24/18G.
Old Nov 10, 2008 | 10:22 AM
I just got a pair of K16/16G instock. PM me for best price.
Old Jan 7, 2009 | 04:09 PM
Just received on the shelf right now. 2 sets of brand new K24/18G Kits and 1 K16/16G. Same pricing applies as above.
COBB Tuning
Jan 1, 2025 09:02 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
