996 Turbo Vendor Classifieds
**AMS Product Release: AMS Porsche 996TT 1-Bar Wastegate Actuator Upgrade**
Old Jan 8, 2010 | 11:48 AM
Frank@AMS's Avatar
Frank@AMS is infamous around these parts
The AMS 996TT 1 bar Wastegate Actuator Upgrade is a great way to add horsepower to your 996 Turbo. The OEM wastegate actuators are set at .7 bar which is fine on a stock vehicle but once the boost levels are raised, the OEM actuators will blow open under boost. This hurts performance by not allowing you to hold your target boost level to redline or even worse not allowing you to reach the desired level at all.
By upgrading to the AMS units, you will eliminate the possibility of your wastegates opening prematurely, ensure maximum boost all the way to redline and allow for pre-load adjustment. These are completely bolt on and will work on any 996 based turbo that utilizes the stock wastegate actuators.
Features
  • Allows turbos to achieve higher boost and hold target boost to redline for increased horsepower
  • Bolt on installation with pre-load adjustment
Applications
  • Porsche 996 Twin Turbo – Compatible with K16 and K24 based turbo’s.
  • Fits all USDM & EDM
Note: These wastegate actuators are designed to maintain higher than stock boost levels, AMS performance insists that your vehicle be re-tuned when installing these units to prevent engine damage.
$349.95
CLICK HERE TO ORDER
Old Jan 8, 2010 | 12:25 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Awesome! No bend on the threaded portion of the rod, FTW.
joseph_number1
Jul 19, 2018 05:45 PM
Chris Green@USP
997 Turbo Vendor Classifieds
Jan 28, 2016 02:22 PM
TrackOne
Aug 20, 2015 12:56 PM
Chris Green@USP
Aug 20, 2015 11:30 AM
