Magnetic Battery Charger Hook Up
We put this trickle charger set up together for a customer on his 997 Turbo. This hook up with come apart without any damage if he backs out of his garage and forgets to remove the charger. We thought this might be something that the community would be interested in.
The magnetic hook up is water proof and short proof, it is made in Germany and comes as a factory option on some Ferrari models.
The connector kit is $59.95.
We also put together a kit with a CTEK trickle charger for $199.00.
It will come with the CTEK trickle charger and we solder the connection on to the charger itself. We also supply the battery cables with about 8' of wire so you can make the connection on the car up pretty easily.
This is a great DIY'er project.
Give me a call to order at (310) 533-8900 and ask for Craig. I have a limited amount of chargers right now but I have plenty of connectors if you want to add it to your current trickle charger.
